Dyno mode on W212 E63?
go temp screen, key pos 1, press/hold answer and quickly press and hold OK. Nothing happens.
Anyone knows what to do?
EDIT: Never mind, I got it working. Had to play with it a little and bam Dynomode came up. Jeremy from OEtuning helped me out to get it right.
can you please elaborate a little on how to do it.
What's temp screen?
Thanks.
I try the following: radio off, door closed, ignition position 1
Select settings, instrument cluster, permanent display, outside temperature.
Press&hold call button , quickly after press&hold OK button.
Nothing happen.
Am I missing something?
Can I dyno just by switching ESP off?
- before turning off ignition, navigate to the "mileage screen" (make sure any errors are reset)
- turn off key and close door
- do not touch any pedals or buttons other than descibed next
- put key in ignition
- turn to position1
- press and hold "answer" followed by "ok" in fast succession
- a new menu will appear on screen use left "Up & Down" arrows to navigate to "Dynomode"
- press "Ok" to enable
- turn on ignition
https://oetuning.com/blog/?p=224
