removed charcoal filter: FIRST IMPRESSIONS
So I changed my oil and decided to delete my charcoal filters as well.
I didn't find any DIY's so i just messed around and figured it out my self. I opened the air filter boxes and without fully removing them I pried out the top upper filter which i assume is the "charcoal filter"
I honestly have not felt any improvement or gains from this mod, high end power feels stronger but that may just be due to the fresh oil.
The only noticed difference is that the car switches gears harder and feels like the shifts are faster and harder (little stronger kick). Is that a common advance?
Will the dealer give me a hard time if they find these filters missing?
I would put them back, they are there for a reason.
Also I would question whether or not the charcoal filter was engineered to serve as a secondary filtration system for sub-micron particles when used in conjunction with the primary filter medium. As I understand it the Euro models do not have the charcoals, so if they are using the same primary filter then that would answer this question.
If you are convinced that it's safe then by all means go for it.
