51 PSI???
Old Dec 28, 2011 | 12:42 PM
E63AMG's Avatar
51 PSI???
I have a 2012 E63 with the optional 19” 5-spoke wheels, and the factory-supplied Pirelli PZero tires. I noticed that the recommended tire pressure for both front and rear tires on the sticker inside the driver’s door jamb is 51 psi!
I don’t remember seeing such a high number before on my previous tires. Is 51 psi a typical pressure on these low profile tires?
Its interesting to me that the writing on my PZero tires themselves that states their 51 psi maximum pressure is sooooo small its literally almost unreadable. I had to use a flashlight and really look hard to see what it said.
Old Dec 28, 2011 | 12:48 PM
vdubpower's Avatar
i drive them all, fast and hard
seem hi, i thought most standard pressures are around 36ish
Old Dec 28, 2011 | 12:51 PM
hyperion667's Avatar
2012 CLS63
jesus that does seem high, the indy shop I use
set mine to 40 all around,and I thought that was high.....
even though I let some out of the front....
Old Dec 28, 2011 | 04:16 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
MB has different tire pressures depending on the load. What does it say on the fuel filler door? I know for my '10 it is 35/39 on the B-pillar--that actually is assuming max load on the car.
Old Dec 30, 2011 | 03:50 AM
_AMG_'s Avatar
C63
That's very high, I would stick to around 36-38 psi.
Old Dec 30, 2011 | 12:09 PM
Vic55's Avatar
Administrator
51 psi is full load (4-5 passengers luggage and speeds over 155mph which wont happen)... Id run 36 to 38 psi cold all the way around.
Old Dec 30, 2011 | 07:18 PM
otakki's Avatar
With 51 psi, you sure are gonna pick up all the nails on the road. I still can't figure out how high pressure increases the odds of getting flats from nails.
Old Jan 3, 2012 | 11:05 AM
thunderMB's Avatar
E63
Look inside the fuel filelr door.
It has detailed pressure for various scenarios, and yes for normal driving the required pressure is about 36 psi.
Old Jan 3, 2012 | 06:33 PM
otakki's Avatar
This year around the snow belt area is crazy since the temperature fluctuates so much I have to adjust the psi every few days.
