Airmatic Malfunction
Once lifted, I used jack stands on the outer ends of the cross member.
Lifting the rear, I found the front part of the diff to be the only option.
I used a block of wood and stayed clear of the cooling fins.
I could not see a way to lift on the outboard jacking points without some kind of jacking puck to fit in there.
After hitting OK it goes away and does not return.
The dealer is clueless to the cause and says it's common and people just live with it.
Yes, I am looking for another dealer.
These jack pads are a work of art.
When dealer looked at it they said they only saw one instance recorded and blamed it on low voltage errors.
However, it occoured at least 6 times before they saw it and at least 8 times since.
The SA is still trying to talk me into living with it, although he will be getting my car back for this and the steering rack noise.
Both of which are unfixed after the 1st 3 day visit.
In fact, not a single 1 of 4 things got fixed on that visit.
Not sure a warranty is worth much with this poor of service.
It seems like they don't want to bother trying to fix things untill I bring the car back with the same complaint multiple times.
It makes a mess of the cars service record, with all the repeat visits.
Get this, my SA stated that me changing my battery must have caused a low voltage error that triggered the Airmatic Malfunction.
Is that a bunch of rubbish or what?
How does that apply to all of the recourring malfunctions, before and after the battery change?
I just hope the techs use better diagnostic logic than the SA.
Most airmatic issues occurred on cars with all 4 corners having the system. Our cars do not- they only have it in the rear which reduces the risk of failure greatly. If you are under warranty it will also give you piece of mind.
I had this message pop up a few times.
Each time the dealer told me: "No fault codes found",
and of course they can't "fix what isn't broke"...
They told me to just ignore this error message untill it goes away...
Seems they can't fix anything that isn't a broken - completely KAPUT.
yes, I'd certainly say off to the dealer with you!
