We did a prior intro sale for the KW HAS Coilover System with our Rear Adjustable Links prior. We now have more stock on the kits so they are ready to go.
We did confirm fitment for the E63. The rear adjustable links are needed as the KW links included with the KW kit alone sets the air ride too low for the E63. This kit is the perfect solution for front and rear ride height adjustment.
PM for pricing and questions.
Prior threads with info on the kits:
https://mbworld.org/forums/cls55-amg...ble-links.html
https://mbworld.org/forums/w212-amg/...ble-links.html
In stock, ready to ship to you today!
Thank you James for sending out the KW’s at a moment’s notice.
All, I will be installing the KW H.A.S.Coilver + Rear Adjustable Links hopefully this coming weekend if I can get all the needed tools/parts in. Can you guys provide me with some technical info as I do not have the vehicle yet (just purchased a 2010 and incoming on 7/4)?
1. What are the tightening torque specs for the 2010:
a. Nuts on strut mount to strut tower
b. Piston rod nut
c. Sway bar bearing nut
d. Lower strut mounting bolts to hub
2. For the rear adjustable links, what is the correlation of the link length to ride height? Is a longer link increasing or decreasing the height? This info will allow me to have a good starting point knowing the KW’s links lower the vehicle more than desireable for most.
3. What is the part number for the Mercedes camber adjustment bolt for the front to dial out the added camber?
4. Any recommendations on where to get an alignment done in Dallas? If taking it to the MB dealership, step 3 wouldn’t be needed as they will install it if need (hopefully).
I will document the process with photos for future DIY installs.
Thanks,
Josh
b. Piston rod nut
Thanks,
Josh
I do not want to mis-inform on the torque specs. I will need to double check and follow up.
On the lowering links, in the rear a shorter link is lower. Our links (as shipped) are shorter than stock but longer than the ones that KW supplies so I would recommend installing them as shipped 1st and then see whether you want them lower or higher.
I did find the camber bolt part# for you, check #2123330071
Thanks again for the order, be sure to call the shop if you need any support with the install. We just finished another install in house on another E63. I will post some photos tomorrow for reference.
Here are some after photos of our recent local install. This is the KW HAS with our rear adjustable lowering links on the E63. Rohana RC20's in Matte Black - staggered.
Just got my adj lowering links installed and my suspension is dialed in. The links provided with the kw kit make the rear sit way too low with very little air. The ride before was unbearable. Raised the rear about a .5 inch. Night and day difference.
Actually enjoy the ride. The links were easy to install and make fine adjustments. Glad I chose the adj links compared to the other options out there. Great quality product and excellent service from advanced performance. Pictures coming soon.
Quote:
ExploreThanks for the PMs. If there are more questions feel free to ask.
Still have a couple sets ready to go.
2 kits left at our current pricing.
Still have a set in stock.
Still have one set ready to go.
In stock, good to go for you!
In stock!
Ready to ship!
PM me the price, a friend got theirs from you and had all good things to say. Also posted in the other post.. Thanks in advance.
