Cold Weather Air Suspension Malfunction?
This results in needing to drive 50 mph or less for a few miles...stopping the car. Stopping and restarting the engine. After which, the rear raises itself as it should, and is back in working order.
Definitely temp related, just curious if it's somewhat normal or an issue that someone else has come across.
Fact of the matter is the tolerances for if the rear end of the car ever sinks like that are minuscule. If anyone is getting that error repeatedly there is likely an issue and it's likely the bellows.
Thus should I bring it to the service even if the rear has not dropped at all?
But there shouldn't be any noticeable dipping of the rear end when it's parked for any period of time. Cold weather or not.
If you see some lowering that you think is abnormal and/or you get that malfunction warning on the dash, make a service appointment.
Then, do one of two things. Advise them that based on the experience of others close to you it's likely the bellows. OR bring to their attention what my service advisor told me about today: There is a case document from Germany that tells MB to replace everything if they find any moisture in the system, as it will contaminate all components of the system. In the event they test for moisture and find it, they will go ahead and replace all components of your suspension.
just got off phone, can you guess what he said I need to fix first. Level sensor in compressor, compressor, valve block.....hmmm where have I heard this before, the original author of this thread has the same thing.
I am going in and requesting only the bellowes be replaced. Do you concur still years later that this is the way to fix this issue?!?!
new member here, got my cls in September.
cheers guys . Thanks for all the info on this matter
ethric
ethric
ethric Kadey
ethric Kadey
I saw somewhere on here someone had mentioned around 700 a piece for them so I figured I was close to that price
This took 4 visits to the stealership.
My 2014 gl450 has 85k on it. I live in TX and woke up and found my car tilting on the driver's side. Started the car and car went back up but after driving for 10 minutes I got the message compressor cooling tg hen the the malfunction message and the car starts going low . Took it to Mercedes they indicated a small leak in the front left struts. They said the suspension usually start to fails after 80k. I really believe the weather dramatic change from around 32f to 5 F caused triggered this. I am just sharing experience in case others are having similar experiences.
I read it’s allowed to drop 1mm per degree dropped in Celsius. 25 mil in 24 hours is a lot. Especially if it didn’t drop 24 degrees. Hopefully yours stays fixed. I haven’t had an issue at all since I replaced my bellows. Cheers
