Transmission not shifting
Btw I live in the mountains of Colorado and the nearest dealer is 200 miles away.
I had the same issue with my E63 AMG (2014). I can give you one tip. You can chose gear but very fast after engine start. Then gearbox should work ok, however I was unable to change from D to R or from R to D unless I switched off the engine and turn on again. Tu get P I had to open driver's door.
After visiting the service I had replaced all switch module. Good for me, that Poland is close to Germany and my car was fixed within 4 days, including transport of the module (it was ordered in Germany).
I have read many posts, because i have the same problem, but there is no result
When i accelarate- i feel vibration from gas pedal, also i feel strange vibration/shaking from transmission (under of driver and passenger center), i have changed all mounts engine and transmissions, also i changed spark plugs, oil filter and oil....
This feeling comes ONLY when i am accelarating from 0 in low rpm,
I thought it was transmission torque, but my car is not under warranty and i dont want to loose money if its not
does anyone have the same problem? i think it is ignition coils, maybe im not the onely one person who has the same problem
i check, in C/S/S+/M - same problem. When i turn in R and go in back, this vibration is coming again ...
if its torque convertor and frictions are damaged, why it comes in when i starting accelaration 1st , 2rd , R - gear ?
