Oil Change 2014 E63 AMG S
Old Jan 24, 2014 | 10:16 AM
97jagxk8's Avatar
2014 E63 AMG S Wagon
I have almost always changed my own oil and filter. However, this car scares me since the owner's manual does not even show accurately where to find the dipstick. I finally found the dipstick on the back side of the engine --towards the right, but I am wondering how difficult the oil filter removal/installation and drain plug access are. Does anyone have any photos or advice on this process and the location of the filter and drain plug? How difficult is it? Is the Mercedes oil filter the only oil filter (that is OK because I will probably use it anyway)?
Old Jan 24, 2014 | 12:28 PM
benyl's Avatar
'10 F150 FX4 SCrew. '14 S212S
The filter is easy.
To change the oil, you suck it out of the dipstick tube.
You will need something like: MV7300
http://www.mityvac.com/pages/products_fee.asp
Old Jan 24, 2014 | 12:40 PM
OWLY's Avatar
2021 G63 & 2022 G63
A DIY on this would be awesome.
Can't you drain the oil traditionally rather than using a Mityvac? I'm concerned about the leftover at the bottom of the drain pan when using a Mightyvac...
Old Jan 24, 2014 | 12:44 PM
97jagxk8's Avatar
Me too. I am traditional on changing oil from the bottom, particularly when you usually must change the filter anyway from the bottom.
Old Jan 24, 2014 | 02:45 PM
benyl's Avatar
You get more oil out by sucking it out. Also, the filter is changed from the top, not the bottom.
when you take your car in to MB, they suck the oil out.
Old Jan 24, 2014 | 03:01 PM
vdubpower's Avatar
i drive them all, fast and hard
u just need to remove the protection covers underneath, otherwise its no different than any other car
Old Jan 24, 2014 | 04:00 PM
emericr's Avatar
2021 Porsche TTS
I just did mine. Piece of cake with a mityvac. No need to get dirty.
The oil filter is in the right front of the engine. A good ol wrench will do the trick.
Took me 15 mins
Old Jan 24, 2014 | 05:31 PM
97jagxk8's Avatar
Took me 15 mins
Thanks for the location of the oil filter. I have a mityvac, but don't use it for oil changes yet. I will probably venture an old-fashioned oil change at about 6K miles and document it for those who still like to do it from the bottom. Thanks to everyone for their advice to me, the newbie Mercedes owner.
Old Jan 25, 2014 | 03:02 AM
OWLY's Avatar
2021 G63 & 2022 G63
Can't wait to read about your experience.
Old Jan 25, 2014 | 12:36 PM
2012 merc amg's Avatar
2018 S560
The oil filter is a spin on right or a cartridge? I don't even know? Wheres it said above it was easy to change I'd assume it's a spin on filter?
Old Jan 25, 2014 | 10:14 PM
benyl's Avatar
The oil filter is here. Unscrew the black cap and the filter is inside. This is the left side of the engine (when sitting in the driver's seat) just under the intake flex tube. Sorry for the crappy iPhone pic.
Oil Change 2014 E63 AMG S-fd55db17-5bd1-47fb-b9fa-55f00c49c1e7_zps7e351a20.jpg
Old Jan 27, 2014 | 06:02 PM
97jagxk8's Avatar
I don't think I would have ever seen it without you photo. Thanks. Now all I have to do is drive it another 5000 miles! The bad weather is not cooperating with pleasure driving right now.
Old Jan 29, 2014 | 10:54 PM
2018 S560
Thanks for posting. Just took my car to the dealer for a oil change today, looks pretty simple. Just thought it would be a good idea to get the whole car checked over. $120.00 well spent.
Old Jan 29, 2014 | 11:03 PM
mercedes4ever's Avatar
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
Have to disagree with this statement, draining the oil [warm oil], through the drain plug gets more out than sucking alone. If you drain it cold, yes you might not get it all out due to the thicker cold viscosity of the oil. Always do it warm - hot.
Old Mar 31, 2015 | 03:36 PM
PeterUbers's Avatar
What oil does this engine need?
Old Mar 31, 2015 | 03:48 PM
97jagxk8's Avatar
9 quarts 0W40 synthetic. I use Mobil 1, which is a brand that is approved.
See http://bevo.mercedes-benz.com/index.php?language_id=1
Old Apr 1, 2015 | 12:46 AM
PeterUbers's Avatar
just checked my dipstick (blue one near firewall) and after i first pulled it out, it was dry, I placed it back in all the way seated, then pulled it out, and the oil level is now clearly between min and max. Cleaned it a couple times and re dipped it and still between min and max... weird.
Why would it be dry like that after sitting for only 2 days? I'll check again and add a few ounces of oil if necessary. 3500 miles on the ODO, fairly easily driven, not much hard driving... can't imagine I've burned through much oil.
Old Apr 1, 2015 | 07:26 AM
unagi1's Avatar
'14 C63 507, '11 C300, '96 Cobra, '91 Mr2
I don't think that is anything to worry about, it's happened to me before one a number of cars when checking cold. I like to warm up car first, shut off and then check (especially when adding fresh oil to the system while cold, it may need some more after it circulates through initially).
Old Apr 1, 2015 | 08:55 AM
97jagxk8's Avatar
My car showed absolutely no oil, completely dry, even to the end of the dipstick when I first checked it after driving 600 miles and picking the car up from Germany. I was shocked, as I have never seen this on any car before. After researching the no-oil-dipstick on the Internet, it seems this happens on Mercedes sometimes. As you and I found out, just put the dipstick back in and retry to get the correct oil level. I still can't figure out why or how this happens. Best of Luck!
Old Apr 1, 2015 | 07:01 PM
PeterUbers's Avatar
Good info guys thanks!!
It's 76 degrees out here ... Need to go out and spank some American muscle
Old Apr 2, 2015 | 01:12 PM
MPR's Avatar
MPR
E63S Estate
Will this work?
MityVac MV7201
Amazon.com: MityVac MV7201 - 8.8 Liter Fluid Evacuator Plus: Automotive Amazon.com: MityVac MV7201 - 8.8 Liter Fluid Evacuator Plus: Automotive
Old Aug 28, 2018 | 12:51 AM
delirium's Avatar
C350
Can anyone tell me what size socket to remove the oil filter cap/housing?
Attachment 410253
Old Aug 28, 2018 | 03:40 AM
EddieK's Avatar
2014 E63S Steel Grey/Beige Nappa, Lexus GX470, Honda Accord
27mm
