That is the same info as in the owners manual that came with the car. However, back where the dip stick shows in the manual for a car with a gas engine, there is what appears to be an electrical connection - and not an obvious dip stick. That makes me wonder if there is a low oil electronic signal on the 2014 E63S. In the owners manual it says the oil dipstick should be on the passenger side for gas engines and on the driver side for diesel engines. On my car there is a dipstick on the driver side with a blue cap (not a ring as shown in the manual). I am assuming that this is for the transmission fluid. Would someone else with a 2014 E63S wagon please check to see if you have an obvious dip stick on the passenger side or if you have found that the blue-capped one on the driver side is for engine oil. Thanks.
