Emergency Key Problem with Smart key
If so, unplug or remove the battery from the Smart key and store it somewhere else, like in the glove box, in a bag with the requiered small screwdriver to place it back. Unlock the doors with the mechanical key and reconnect your battery once inside the car.
Wrapping it in a couple layers of thick aluminum foil might work.
You're just looking for something to block the radio frequencies.
Poke around on amazon and ebay. RF blocker or rf shielding case. Some combination of those words.
Super-fancy solution:
http://www.ramayes.com/FOBLOK_EMI_RF...y_Key_Case.htm
The car functions as it would if there was no keylessgo option installed.
Removing the receiver is a good idea if you wash the car. It will preclude the trunk from opening randomly and other oddities.
