Going from Corvette to 2010 E63
With the 2010 you do have the electronic suspension button stiffens the suspension up.
To be honest going from a LS motor to an AMG its just a different driving experience.
P.S welcome to the costly repairs when something screws up xD
It's a 4400lb sedan... No it doesn't perform like a sports car that is a svelt vette but it also is a rare super sedan that can outperform most other sedans on the planet compared to the plethora of sonatas and camrys out there that can't do anything but get you from a to b with the kids strapped in the back
In sport trans and sport suspension mode I'm still incredibly aware I'm driving a sedan ... Test drive and see what you think
I drove my mates C63 amg, the c63 amg feels a lot sportier to drive as a sedan probably because the size of the car is a little smaller than the E63.
but the e63 just has its own comfortable feel like its the perfect "sleeper".
As for the head bolt issue, I can't afford a 2011 and I don't see that many of them, I will have a 5 year 125K warranty so hopefully it breaks during the warranty period.
Will the warranty cover the cost of front brake rotors which are 800.00 to 1000.00 each and pads at 100.00 to 200.00 a set for the front? Transmission service of 500.00. 9.3 quarts of 0w40 Mobil 1 oil for each oil change. If you have not owned a premium luxury car before then you should read up on maintenance cost before buying since you stated that a 2011 may be too expensive for you to purchase.
I regularly put the Z06 in the air. I've had several LS motors in and out of C5's, C6's, and I'm past the point where anything on the car intimidates me other than the ring/pinion and paint work.
I've replaced brake parts and worked with a qualified technician to learn how to pull the oil out of the M157 (which may be different to your M156). Both of our cars use two-piece front rotors, for which rings are not available (either you place the rotor/hat with a stock pair repeatedly or you purchase a new set of rotors form RacingBrake which allows you to replace rings only.) You will not find a pair of those two-piece rotors other than in some kind of weird liquidation sale for less than $1200 a pair. I've tried. Decent (and I mean a good balance of rotor wear/bite/dust) pads are $300+ for the front set.
The oil of the M157 is taken out the top of the engine using a vacuum pump. Its not impossible for a home mechanic, but one certainly needs several hundred $'s worth of tools. Changing the oil in the Z06's dry-sump setup is really easy in comparison. The transmission service and rear-end service (for the LSD) are things that I want the dealer to do in order to preserve my warranty.
If you plan on learning how to do these things and acquire the tools, I wish you good luck and hope you will share your experience with the community. But with my level of experience, the E63 is still a car with a very, very different cost of ownership than the Corvette. Its one reason I have hesitated for a long time to trade my Z06 for an M157 SL63 or 991 Turbo. The price of the car is only part of the financial hit.
Here is a link to the maintenance manual http://www.mbusa.com/vcm/MB/DigitalA...nce_Manual.pdf
Anyway, the interior was a little rough, the unlock button on the drivers side was essentially worn off and the on button in the middle of the radio/navigation section was wearing too. Are these easy to replace?
Anyway, the interior was a little rough, the unlock button on the drivers side was essentially worn off and the on button in the middle of the radio/navigation section was wearing too. Are these easy to replace?[/QUOTE
Since you mentioned the ride, you may like the E550 with the sport package. I came very close to getting the E550 when I was shopping. And a 2011 E550 sport or maybe 2012 E550 sport will be about same price as a 2010 E63.
Also when driving and manual shifting, I noticed sometimes it seemed like I had to click the paddle twice to downshift, was I just clicking them too quickly? I was trying to drop as quickly as possible from 7th to 3rd or so.
