E63 $2600 front brake job after 25k miles?!?!?
Old Nov 6, 2009 | 05:27 PM
chitown E63's Avatar
2007 E63
So I have owned a few AMG cars but have never had to do a brake job because I trade pretty often. I took my car in for D service yesterday and was quoted $2600 for front brakes, they said the rotors were bad as well and couldn't be turned. I drive my car hard but not hard enough to toast rotors and brakes in 25k miles. Am I getting ripped off? Is this to be expected, I know this car is expensive to maintain but come on.
Also, if anyone is running into this are there aftermarket options, and other trustworthy shops in Chicago that aren't MB.
It is an 2007 E63
Old Nov 6, 2009 | 05:30 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
E63 Breaks are very expensive but only 25k miles..... you better go check others indy shops.
Old Nov 6, 2009 | 07:37 PM
xabo's Avatar
'20 S63
Mine after 21K
https://mbworld.org/forums/w211-amg/...ds-change.html
Old Nov 6, 2009 | 07:50 PM
DAGREEKNYC's Avatar
Registered User
2019 s560 sedan
i had to do the breaks at 18k . MB "prefers" to replace the rotors with every AMG brake job. i didnt need them so i just did my brakes . buy the parts yourselve and have a mechanic u know do them , even if u need rotors u will save a bundle going outside of the dealer
Old Nov 6, 2009 | 08:15 PM
guysandiego's Avatar
2006 E55 AMG --old cars -- E39 M5, 2.7tt Audi S4, E36 M3 **Ducati 996, 748
Well, my dealer quoted $900 for front and rear brake pads--- they said my rotors were fine --- So, i would not be surprised if they quoted you that much $$$$...it is the dealer. I ended up buying EBC-reds and took a few casual hours and did them myself... it was a great decsion!
Old Nov 6, 2009 | 11:05 PM
jpohl402's Avatar
E55 then E63, now back to an E55
Here is what I know...
Rotors are two-piece & have a floating hat (secured with bolts). This improves on heat dissappation. Retail on each front rotor is $900. Wholesale is about $700... this is still very expensive compared to E55 rotors at $125 each. Although they do not recommend it, I found a place (and it can be done) that re-surfaced the rotor - based on thickness - for I believe $100 each. Not sure about the "turning" of cross-drilled or slotted rotors. I didn't want to be stuck with a stiff repair bill either because I don't even go to the track.
Now on another note, the 63's pads are MUCH easier to install and less labor intensive than the E55 because they removed the system (can't recall name currently) that had to be disabled or it may clamp the rotor shut and sever fingers. The pads are now incredibly easy to change.
Hope I was of some assistance and good luck.
Old Nov 6, 2009 | 11:14 PM
jangy's Avatar
2015 S212
I thought retail on the E63 rotors was closer to $1300? Also, if you have a floating setup, consider simply replacing the ring. Many companies make replacements. the hat is what is the core. Any E63 guy can upgrade the rotor and hardware vs replacing the entire rotor. You would save weight, which is a major feel bonus even if you do not track it.
Old Nov 7, 2009 | 01:37 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Front pad...$225.00 list $288.00
Sensor.......$16.00 each x2 front & rear
Rotors........$795.00 each..list $920.00 each
And yes, they are easy to change, just got a lesson from a tech at Laguna Seca preping the cars for tomorrow.
Old Nov 7, 2009 | 01:48 AM
bobgodd's Avatar
2004 E55
I'll do it for $2400.
Old Nov 7, 2009 | 01:49 AM
jangy's Avatar
2015 S212
I'll do it for $2200
Old Nov 7, 2009 | 01:58 AM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
Contact member nick55
He will give you the best Mercedes service here in the Chicagoland area!
Old Nov 7, 2009 | 02:58 AM
jpohl402's Avatar
oh Chitown E63...
you CAN in fact (if you choose) replace the rotors with a one-piece E55 rotor. they fit but you will lose some (non-noticeable) braking unless at the track. for city driving - if you can't get them resurfaced - I would probably do it...
Old Nov 7, 2009 | 03:26 AM
VCA_AMG's Avatar
2018 E63S Wagon
Those prices indicate $2500 isn't such a bad deal, given labor costs & a shop's need to actually turn a profit.
I'd rather do the work myself too, but given how IMPORTANT the front brakes are and how much we demand of them (and how well they perform), something's gotta give. Can't get that type of braking performance w/out giving up some lifespan, or vice versa.
Old Nov 7, 2009 | 03:41 AM
maybe it depends on the year -- but changing my pads could not be any easier... tap out 2 pins per caliper.. squeeze the pistons in with your Fingers.. Yes, your bare hands- no problem... that is it!!!
Old Apr 29, 2010 | 08:01 PM
bennyj's Avatar
2007 AMG E63
Hate to bump this up from the dead, but i was just quoted $3295 including tax and labor to replace the front rotors, pads and rear pads on an 07 E63. I almost passed out when i heard how much it was. The car is at 47k miles so hopefully this wont be an issue for at least another 50k miles. Is this pricing normal for any MB dealer?
Old Apr 29, 2010 | 08:42 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Wow, dealers must be really hurting, they keep raising their prices higher and higher.... that's very steep bro
Old Apr 29, 2010 | 09:09 PM
bennyj's Avatar
2007 AMG E63
Tell me about it. Knowing im gonna have to dish that out makes me cry. There goes my vacation
Old Apr 29, 2010 | 10:24 PM
jtc55's Avatar
08 E63
what city do u live in?
Old Apr 29, 2010 | 11:13 PM
220S's Avatar
Porsche 991S, Cayenne S, 1972 BMW 3.0CS E9 Coupe
Yeah, Benny where are you located? Go find a good Indy. There's no reason for the dealer to have to do the job, it's a maintenance item not a warranty issue, etc..
Have an Indy who knows AMGs do it with OEM parts and you'll save $$$.
Old Apr 29, 2010 | 11:36 PM
bennyj's Avatar
2007 AMG E63
Houston, TX. The dealer (Star Motors) was already given the go-ahead on the repair. I had to get it done asap, didnt have any other time to do it. Should have it back tomorrow.
Old Apr 29, 2010 | 11:45 PM
motorkas's Avatar
a Rivera...via a Custom 24, Strat and Les Paul
Next time contact Shardul and a couple of the other Houston guys on the forum - could possibly save your vacation next time
Old Apr 29, 2010 | 11:50 PM
bennyj's Avatar
2007 AMG E63
Yeah, lurking the forums for a month and a half, i should have setup some connections, lol. Oh well, next time.
Old Apr 30, 2010 | 12:00 AM
motorkas's Avatar
To give you an idea of what your in for - Shardul went to MB Greenway to checkout my car for me (didn't know him and it was in response to my first post on the forum). Just prepare yourself for the "63's are slow" statments
Old Apr 30, 2010 | 12:20 AM
bennyj's Avatar
2007 AMG E63
LOL i didnt get the 63 for speed.... i got it for super expensive brake jobs. :p
Old Apr 30, 2010 | 12:55 AM
AUS-E55's Avatar
CLK-63 BLACK/2014 E63S/2013 ML350
Shardul is great guy and always seems to have the time to help anyone out, we meet up quite often here in Houston, make sure you PM one of us before you do anything, if we cant do it, we can find some one better and cheaper than the dealer for you.
