Distronic Plus turns off
Old Apr 16, 2015 | 06:55 AM
robl45's Avatar
2011 AMG E63
Twice yesterday I was driving with distronic plus and about 10ft from stopping in back of a car, it decided to turn off. Has anyone else had this happen? If I hadn't hit the brakes immediately, I would have had an accident.
It also stops me much closer than I'm comfortable with in back of other cars.
Old Apr 16, 2015 | 10:07 AM
grimesch's Avatar
2015 AMG E63S 212
You should be able to set the distance with the knob on the histrionic lever (you know, the one you always hit when wanting a turn signal).
Old Apr 16, 2015 | 12:32 PM
PeterUbers's Avatar
Found the distr plus unsafe in my previous to e550 vehicles and therefore opted not to get it in the E63
Had the exact same thing happened to me multiple times when I had the 550
Old Apr 16, 2015 | 06:12 PM
robl45's Avatar
2011 AMG E63
I know I always hit it, but its not a distance issue.
Old Apr 17, 2015 | 02:45 PM
unagi1's Avatar
'14 C63 507, '11 C300, '96 Cobra, '91 Mr2
man, what's with all the gremlins...
Old Apr 17, 2015 | 03:59 PM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
I have it both my cars and use mine in traffic all the time. I made sure I got an E that had it after experiencing it my C63. Only time it has been inoperable is when there was snow/ice buildup.
Robl45 - I honestly think your system has something wrong with it since this isn't your first issue with the Distronic. It should absolutely follow the car in front of you to a stop without issue, and a tap on the gas or cruise stalk should start you up again. I would take this to a dealer if your under warranty and have them address this safety issue.
Old Apr 17, 2015 | 06:07 PM
robl45's Avatar
2011 AMG E63
I would agree with you, but no one can seem to tell me how its supposed to work. I took it to the dealer before I was out of warranty a couple of months ago as I didn't think the presafe brake is working as it should and they said it is working correctly. I have extended with 100 deductible so when I take it to my independent mercedes place to do the transmission fluid, I'll probably have them check it out.
It does work as you describe most of the time, although it stops on top of the car, like way less than a normal person would stop and I don't drive normal and it stops closer than I would stop. This is in traffic on normal streets so not what its made for, but even when driving home from chicago on the highway through atlanta, traffic came to a standstill and I just about rear ended the car in front of me. I'm thinking it works but not quite the way its supposed to unless this is normal.
To me if I"m coming up on a car fast, it should be beeping and braking me, not beeping when I'm about to hit the car waiting for me to hit the brakes.
