OBD2 Gauges for Bi-Turbo Cars
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
Aeroforce has developed a OBD2 gauge for 2008 and up MB. This single gauge will support engine and transmission parameters. All data to the gauge unit is supplied from the OBD2 port. Analog input is also available to support a wide band AFR controller.
I can setup a group buy for 230 per unit plus ship
![](http://imagizer.imageshack.us/v2/xq90/673/BSJgOb.jpg)
Sir do you have similar for the V12 biturbo cars? ie w215 CL65 AMG?
Great, I am in for the W215 gauge.
I also own W211 E55, wish it works on it too.
Following are the parameters you can view for the V8TT cars
IAT
Ambient air
coolant
cat temp b1 & b2
rpm
boost
MAP
MAF lb/min
MPH
Throttle %
Ign Advance
STFT
LTFT
engine load
fuel status (open /closed loop)
fuel rail pressure
fuel rail pressure (direct injection)
MPG
HP
run time
barometric pressure
battery voltage
oil temp
Lambda
commanded EQ ratio
AFR commanded
TCC slip
TCC state
current trans gear
trans temp
torque to trans
analog 1 input
analog 2 input
The gauge has a performance timer (0-60, 1.8th, 1/4 mile), read and clear DTC's, record, cyclic scan.
IAT
Ambient air
coolant
cat temp b1 & b2
rpm
boost
MAP
MAF lb/min
MPH
Throttle %
Ign Advance
STFT
LTFT
engine load
fuel rail pressure
MPG
HP
run time
barometric pressure
battery voltage
oil temp
Lambda
commanded EQ ratio
AFR commanded
TCC slip
TCC state
current trans gear
trans temp
torque to trans
analog 1 input
analog 2 input
Yes it will work on your car.
Mounting locations are all custom that are done by the end user. You can
Modify a 2 1/16 gauge pod to mount it
