BT: W212 E63 & Carbon Build Up...
At 29k Miles on a large engine like this I have to assume there is some sort of build-up just not sure if it is enough that warrants a cleaning or if it is completely choked like other engines in vehicles I own(ed).
Thanks.
Depends on your driving. So long as you go through the rev range (load) few times, it should be fine and helps clean it all out
also its different on force induction cars. from what i am told NA suffer more
but if you really want to know, i think they have a scope they use to look at your engine at the dealer..?
many manufacturers have redesigned their engines to be multiport direct injection where a supplemental injector is installed and a "wash cycle" is implemented into the programming of the injector spray and when the engine is under heavy load. this aids in mitigating build-up.
i have a great deal of experience with having carbon build up removed from Audi & BMW engines and the methods are very similar but i have not had an opportunity to do it on an MB engine.
my friend had an opportunity to break down an m157 engine but he has not made it to the valves yet. waiting on parts from germany:
there is substantial build-up on the piston crown but i am more concerned with IM & Valves or any area that may choke the engine and rob it of power.
Manually scrubbing the valves and media blasting. Seafoam before and after then oil change. This has been the method completed on the vehicles I have own(ed).
Maybe when I'm done rebuilding the S14 in the M3 I'll tear down the intake of the wagon to see the intake valves...
-chris
https://s14net.vbulletin.net/forum/s...nd-scope-creep
-chris
Iconoclast - did you ever open up your M157 and check the carbon build up if it was a possible issue? Am curious if carbon buildup is something M157 motors will be dealing with now that many are getting higher in mileage....
this is the only thread i've found anywhere on the topic of M157 motor and carbon build up in the intakes so maybe the M157 doesnt have the issue as bad as BMW motors where they get walnut blasted to remove the carbon (
curious if anyone has feedback on this (hopefully not which would mean no issues
