DIY removal of w212 e63 trunk chrome molding
I first tried painting it while it was on the car by taping it off but it just didnt come out as good as i wanted it to, so decided to take it off and get a more professional looking end result.
pretty easy to get off once I figured out what was clipped on, what was glued on and what was held on by trunk lock handle mechanism.
- first remove trim tabs in trunk to remove plastic piece shown (then give it a hard pull and it will pop off) and then remove tabs in the trunk liner
when removing the liner you will need to unclip 3 electrical connection shown below (one on the liner and 2 on the plastic piece)
- next you will need to remove this piece below from above the license plate... it was the trickest as there is a piece inside the trunk the holds the trunk unlock handle in.
to access the piece the holds the handle in you need to get at it from inside the trunk... here it is...
first remgve the electrical connector to the trunk handle inside the trunk and pull this clip down and it will release the trunk handle
here it is will the clip removed and here is what the clip looks like
now you can pull the black plastic assemble out... all thats holding it on now are a few push in clips (in pic i have the clip showing as well)
now that you have it off it should look like this and now you can start removing the chrome piece
to remove the chrome piece you need to get out a razor (exacto pen razor works good) and lift up the chrome at one end and start cutting the adhesive trim tape as seen below
there are also 5 clips that hold the trim and and they just unsnap
now its off and can be painted.... install is just reversed... I used 3m doubled sided auto tape to remount the chrome piece once i plasti-dipped it.... all done now.... looks much more aggressive with the flat black than the chrome.... probably adds 20hp
all i need to do now are the side "v8 biturbo" badges and that will be comestics-wise
then onto renntech turbo upgrades
Thanks in advance.
Attachment 372272
Attachment 372273
Attachment 372274
Attachment 372275
Attachment 372276
Attachment 372277
Attachment 372278
Attachment 372279
Attachment 372280
Attachment 372281
Attachment 372281
Attachment 372283
Attachment 372284
Attachment 372285
Attachment 372286
Attachment 372287
Attachment 372288
Best regards,
Carl
