AMS Cooling setup
Old Jan 16, 2016 | 09:05 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
AMS Cooling setup
We ordered this for a local member. Quality is top notch.
Kit includes OEM cooling divorce kit and distronic bracket.
I should have pics of the install process also in a few days.
Old Jan 16, 2016 | 03:25 PM
kponti's Avatar
E63
Old Jan 16, 2016 | 03:54 PM
joseyu's Avatar
AMG GT S & E63 S AMG
Have the AMS heat exhanger installed in my car, it definitely cools the car down nicely during the hot summer days.
Old Jan 19, 2016 | 03:19 PM
shardul's Avatar
Originally Posted by kponti
did you drop the car off?
Old Jan 19, 2016 | 06:46 PM
kponti's Avatar
E63
Yep just this afternoon
kponti's Avatar
E63
Just the heat exchanger or the whole shebang?
Old Jan 21, 2016 | 12:18 PM
shardul's Avatar
some pics of the install kponti
PM me if someone want to purchase a kit
Old Jan 21, 2016 | 12:39 PM
kponti's Avatar
E63
Awesome, I cannot wait for to get her back!!!
Also does anyone know the part numbers for the intercooler pumps in 2012 vs 2014?
EDIT: So there IS a difference between the 2012 and 2014 (especially the S models) intercooling. The pumps are different is why AMS cooling requires a secondary pump. Also the newer cars come with a auxiliary heat exchanger that the RWD cars do NOT come with. Not to mention there is the split/divorce part of this too.
The AMS kit rectifies all that and adds more efficient primary HE as well as a reservoir to best the newer cars
Old Jan 21, 2016 | 07:40 PM
JoeNobody's Avatar
Mercedes
I believe the secondary heat exchanger comes with the 2012 performance package.
Which pump is used on the 2014?
Old Jan 21, 2016 | 09:36 PM
kponti's Avatar
E63
I have the p30 package and no secondary heat exchanger
Old Jan 21, 2016 | 09:40 PM
kponti's Avatar
E63
So AMS full cooling kit has been installed. I gained almost 3 additional gallons of coolant. The car now has two heat exchangers and a large reservoir. Trick system that allows you to bleed the it with a touch of a button.
I will start data logging either this weekend or next week for iats
Old Jan 21, 2016 | 10:55 PM
KLR CLS's Avatar
CLS63 PP
Cool. Let us know how iats look under load and recovery
Old Jan 22, 2016 | 01:47 AM
JoeNobody's Avatar
Mercedes
Hmm, there was a year that the additional heat exchanger came with some option, and the exchanger was not on the base E63.
Old Jan 22, 2016 | 09:55 AM
Toadster's Avatar
2005 E55 AMG
would a kit like this void the warranty?
Old Jan 22, 2016 | 10:43 AM
kponti's Avatar
E63
Yes the AMG-S all came with an additional exchanger (2014 and up)
Old Jan 26, 2016 | 09:34 AM
kponti's Avatar
E63
I have an update to share: Check out this thread.
https://mbworld.org/forums/w212-amg/...e-weather.html
Old Jan 26, 2016 | 11:21 PM
ringkingpin's Avatar
2014 e63, 2012 Callaway Yukon XL Denali, 1971 BMW 2002, 1968 280se, 1961 T-Bird Convertible
I had AMS put their cooler on my car when it was there for the ECU tune. I figured it was insurance and I get no fad after multiple hard runs.
Old Jan 27, 2016 | 05:36 AM
TX E55's Avatar
Mercedes-Benz AMG E63 & ML350 Bluetec
I am interested to see how well that system stacks-up against what the manufacturer shows on their website for IAT's. I am taking my E63 to Circuit of the Americas in a week and a half for a track day and I want to put it through its paces to see if I get any reduced performance.
Is data logging difficult?
Thanks and good luck with that systems, looks killer.
Old Jan 27, 2016 | 11:59 AM
kponti's Avatar
E63
Datalogging is easy and cheap. I have the PLX Kiwi2 from an old car I just plug into my OBDII port and use Dashcommand to datalog just IAT, RPM and Boost levels
Old Jan 27, 2016 | 01:58 PM
TX E55's Avatar
Thanks! I'll text you a few more questions. Sounds awesome.
Old Jan 28, 2016 | 03:45 PM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
I have a 2014 E63, and I was wondering if all 2014+ models come with the split divorced cooling stock. Because I notice that from the front I can only see one HE inlet visible while the other side is covered up. Or is it that only the S models come with the divorced cooling?
Old Jan 28, 2016 | 04:17 PM
shardul's Avatar
Remove your engine cover and you will see the reservoir for the split system.
