Rear End wobble Under Hard Throttle at Higher Speeds - Please Help
Old Jan 22, 2016 | 04:55 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
Hey Guys,
Having a rear end side-to-side wobble When jumping on the throttle at higher speeds. It sways about 2 to 4 inches at a cyclic rate of about 1 second per wobble.
Today I had a guy trying to get me to go on the freeway and I finally gave in. Just a straight up drag race. With pedal floored at about 110mph to 120mph the wobble became to scary. I was forced to back off. The wobble stopped immediately when throttle was let off. This pretty much takes any kind of wheel balance out of the question.
It seems it must have something to do with the rear axle, or the rear suspension, or a combination of both.
I also have new PSS tires on the rear, but the old stock Continentals did this too.
This problem seems to have developed in the last few weeks. I have punched in the past up to 130 or 140 with no issue. Something is clearly wrong now though.
Any of you guys see any other posts with this issue, besides one that I did a few days ago that wasn't very clear?
I gotta believe this has been experienced by others at some point. I have never really felt anything like this in any car I have driven to include my old W210 E55.
Old Jan 22, 2016 | 06:05 PM
rs4 tony's Avatar
16' E63s Diamond White
Check your center axle bolt of these cars have them. Remove both wheels and it's under the center cap. Dead middle. Had this loose on my Audi s5. As I increased in speed the wobble was increase as well. Almost as if you swerve left the tail end swerves a second delay.
Old Jan 22, 2016 | 06:14 PM
Davidkuo0330's Avatar
2016 AMG S65, AMG GL63, 2012 AMG E63 With AMS Alpha 9 Package, Renntech 200 Catted Downpipes.
Hey V.
Sorry to hear about this. I would stop driving you E63 until you get it fix. Call MB road side assistant and have them tow it to your local dealer and have them trace the problem. If it's too expensive to get it fix at the dealer, at lease you know what the problem is and maybe have a Indy shop fix it. Sounds dangerous.
Originally Posted by Vrodman
Hey Guys,
