what's your favorite brand oil to use in your m157?
Old Apr 23, 2016 | 08:08 AM
rs4 tony's Avatar
16' E63s Diamond White
mobil 1 5w-40 is what my dealer uses...
i want to switch to motel x-cess 8100 5w-40.
i heard some use mobil 1 0w-40(yes its a lot cheaper too)
Old Apr 23, 2016 | 11:01 AM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
mobile1 synthetic 5w-40 when im motivated and order online...0w-40 when i go to autoparts store as they never have 5w40
Old Apr 23, 2016 | 12:05 PM
kponti's Avatar
E63
Mobil 1 0-40
Old Apr 23, 2016 | 01:44 PM
BerndV's Avatar
2016 E63 S AMG
Mobil 1 5W-40 is a low SAPS oil that meets MB 229.51 which is their diesel oil specification. Oils meeting MB 229.51 can also be used in gasoline engines which is why dealers generally only stock the 5W-40. However, for optimum protection in a gasoline engine like the M157, a full SAPS oil that meets MB 229.5 like Mobil 1 0W-40 is preferable.
Old Apr 23, 2016 | 02:40 PM
PeterUbers's Avatar
Mobil 1. 0w-40
Old Apr 24, 2016 | 10:55 AM
JDM_SXE-10's Avatar
2003 E500
My favorite brand of oil on the M157 is the same as on non-M157--Mobil 1 synthetic.
Old Apr 25, 2016 | 01:56 PM
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
I use M1 0W-40 in all my cars. When I jump into a M157 from a M156, it will also be M1 0W-40.
Old Apr 25, 2016 | 01:59 PM
armansd's Avatar
2015 E63 AMG-S, 2005 Porsche 911 Turbo-S
Based on my previous experience with Mobil-1 on my Turbo Porsche, I have used the Liqui-Moly oil which btw is MB approved and very happy.
Amazon.com: Liqui Moly 2332 Leichtlauf High Tech 5W-40 Engine Oil - 5 Liter: Automotive Amazon.com: Liqui Moly 2332 Leichtlauf High Tech 5W-40 Engine Oil - 5 Liter: Automotive
but oil is almost a religious discussion so this is based on my personal experience with a highly modded 996 Turbo, M1 tends to loose its sheering too quickly.
Good Luck
Old Apr 26, 2016 | 11:23 PM
looney100's Avatar
None
0W Mobil 1 used exclusively in my two Benzes and one Acura. Acura gets 0W20, the E250 0W30, and the E63 0W40.
Despite what most guys here will say, brand isn't all that important. If you're using a synthetic oil that meets the MB229.5 spec, you'll never be sorry as it will be a quality oil.
Use a 0 weight oil over a 5W, the 0 will provide better protection than the 5W in both extreme heat and cold.
Old Apr 27, 2016 | 02:00 PM
otakki's Avatar
Why not 0W-40 for all 3 vehicles?
Old May 17, 2016 | 08:37 PM
screw991le's Avatar
2010 E63 AMG
Mobil 1 0-40, I have to add two quarts around 6-8 months into a service and she eats it. Been tested and head bolt tested and told that 2 quarts of burn off is normal. I do want to install a catch can, to see how much is blow by, but have been to lazy to do so. Do you guys think a CC is worth it?
Old May 19, 2016 | 02:07 PM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
Good Luck
LM2332 is good stuff. Mobil is as well
Old May 19, 2016 | 09:57 PM
looney100's Avatar
None
Because of the car manufacturer's oil specs. One grade won't meet the various specs - and messing with the second number of the oil grade can be dangerous.
Old May 19, 2016 | 10:51 PM
2012 merc amg's Avatar
2018 S560
I get the Mobil 1 European formula 0w-40 at walmart for $26 bucks a gallon.
Old May 20, 2016 | 01:49 PM
otakki's Avatar
Now Amazon also has the same Walmart roll-back price at around $23 per 5 quarts.
Old May 20, 2016 | 03:54 PM
JJCTHE1's Avatar
2016 G63 AMG
Geez I didnt even know there were options, thought you had to use the Mobile 1 from the dealer. We have 3 AMGs at my company, and honestly they each burn about 1 qt of oil every 6 to 10 months. We always have a case in our office, we buy a case a year. My partners old 2007 CLS63 would burn through oil even faster than that, he did however beat the heck out of the car.
Old Jul 17, 2020 | 04:13 PM
Mhoughland's Avatar
2105 e63s
Try a little heartier oil if you dont want to burn 1-2 quarts between changes.
Old Jul 17, 2020 | 11:16 PM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
My vote..
Liqui Moly. Quieter and far less consumption in my 157.
Old Jul 18, 2020 | 11:22 AM
ProfessorX's Avatar
2012 E63 Tuned, 2020 Shelby GT350, 1999 S 420
Liqui Molly 5w-40
Old Jul 18, 2020 | 05:47 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
For reference, attached is the current MB 223.2 which defines oil requirements for engine oils. M157 can only use MB 229.5 exclusively, and then 0W-40 or 5W-40 weights.
Regards,
Joe
File Type: pdf
