m157 engine damaged
Old Apr 26, 2016 | 04:13 PM
Werkzeug's Avatar
463, 210, 211
Looks like you dropped a spark plug electrode into the cylinder. Its probably a combo of both, you likely scored the cylinder wall and possibly hung a valve. The oil loss could be due to that or the turbo as well. In fact the spark plug electrode possibly made its way to the turbo through the exhaust valve.
Old Apr 26, 2016 | 04:21 PM
rs4 tony's Avatar
16' E63s Diamond White
Turbo seal or scored wall, motor has to come out to replace either of them anyway. Might as well pull it. Is it under warranty?
Old Apr 26, 2016 | 04:25 PM
Fairbird's Avatar
C300
turbo seal , pretty sure.
Old Apr 27, 2016 | 04:01 PM
mjd222's Avatar
e63
We took out the plugs from no 5 cylinder
And it's cover in oil bad news
But we will do the compression test any way
I will keep update
Old Apr 27, 2016 | 04:04 PM
mjd222's Avatar
e63
But when it happen the engine was coverd in oil to much oil every where
We don't know where the oil came from
And when we moved the air filter we found some oil ( how the hill the oil came inside )
Old May 8, 2016 | 04:39 AM
mjd222's Avatar
e63
Hi
Today I removed the turbo outlet Compressor side I found tons of oil
Old May 17, 2016 | 08:01 PM
  #32
screw991le's Avatar
2010 E63 AMG
Old May 17, 2016 | 08:02 PM
  #33
screw991le's Avatar
2010 E63 AMG
Originally Posted by mjd222
I don't want to open the engine Intel I am 100% that the engine is damaged
The good thing that my 124 E60 still here to use :-)
Intel inside is your first problem, everyone knows and AMD overclocked is better.
