What Gear and AWD config to use on dyno?
Old 09-07-2016, 06:15 AM
Zod
Zod's Avatar
CLS55 2006, CLS 63S 2015
As the title states
What gear have the majority of you used to dyno (biturbo 63) 4th or 5th?
what was the configuration for the AWD reading on the dyno setup?
Thx
Old 09-07-2016, 09:43 AM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
Proper gear is 5th (1:1 ratio) however you will hit the top speed limiter, so everyone dynos in 4th
Old 03-27-2017, 05:44 PM
Amg63-'s Avatar
CLS63 AMG
sorry to revivle an old thread but just want to confirm what gear to dyno at for a tuned 14+ 63S.
Is it supposed to be 5th but everyone uses 4th or is 4th showing the right numbers?
Old 03-27-2017, 10:08 PM
Geno51's Avatar
E63 amg s
some of of the new dyno jets go to 200 mph. My car was dynoed in 5th
Old 03-27-2017, 10:59 PM
Amg63-'s Avatar
CLS63 AMG
cool, but IF the car happened to be dynod in 4th gear are the numbers still accurate? Or would they read higher or lower in 5th vs 4th?
Old 03-28-2017, 12:28 AM
Geno51's Avatar
E63 amg s
Any gear with a higher then 1.1 ratio will always read slighty off. It's hard to explain but for the most part hp will be relative and very accurate using the next closest gear. But peak tq is best measured in 1.1 ratio. With that said because hp is a calculation of tq over time. The best measurement is at 1.1. And with all that said all dyno numbers are really useless. The only thing that ever matters while using a dyno is gains shown. Dyno numbers really mean nothing and should only be measured to show gains or loss.
Quick Reply: What Gear and AWD config to use on dyno?
