Lowered with spacers
Old Dec 15, 2016 | 03:35 PM
RichardCranium's Avatar
My 2014 E63 is lowered with springs in the front links in the rear. I have 10mm spacers in the front 15mm rear and I scrape my front passenger fender on larger dips in the road anyone else experience this? From what I have read these spacers should be fine. Any ideas?
Old Dec 15, 2016 | 05:25 PM
M-Theory's Avatar
M3
My 2012 is lowered and has 10mm front, 15mm rear spacers and it never rubs no matter the driving situation.
Old Dec 15, 2016 | 06:38 PM
Yeah that's what I've seen, shouldn't be a problem. I don't get it, frustrating!
Old Dec 16, 2016 | 11:50 AM
Chris_tA_4's Avatar
A4
your camber settings may be a factor as to why you are scraping
Old Dec 16, 2016 | 01:55 PM
PeterUbers's Avatar
Did you do an alignment after lowering?
Old Dec 16, 2016 | 05:48 PM
CarHopper's Avatar
E63S | X5
Same setup, factory spec p-zero tires, and I rub on dips too but on the drivers side. I can also hear it sitting still and just turning the wheel.
Not too sure what I'm going to do about it and just tucked the car away for winter. I'll probably take out the spacers in the front just to confirm that is what is rubbing and then go with a slightly thinner spacer, or no spacer at all, for the time being.
Another option that crossed my mind was just getting a 245 tire for the front instead of 255.
Old Dec 17, 2016 | 08:07 AM
Yes and the said they got it to factory specs
Old Dec 17, 2016 | 08:08 AM
Was thinking that too going to have the shop that aligned it check camber.
Old Dec 17, 2016 | 08:09 AM
I was thinking of going to an 8mm if I can't fix it with the 10mm
Old Dec 22, 2016 | 03:21 PM
updog's Avatar
2014 e63 sedan
I was planning on doing 15mm spacers on all 4 wheels but not lowering the car at all. Any reasons why it seems many of you do 10's in the front and 15's in the rear?
Old Dec 24, 2016 | 02:22 PM
I think 15mm in the front would push the wheels out too far I've seen some with 12.5mm in the front have never seen 15mm in the front.
Old Dec 24, 2016 | 04:25 PM
threeMBs's Avatar
Only MBs - the best or nothing
Agree that with 15mm front spacers, yielding an offset of 22mm for stock 19x9 et37 wheels, fronts on non-lowered car would poke by about 8mm (or 1/3") at least. I think 5mm front spacers (for et32) will make front wheels flush enough. Even rear 15mm spacers on non-lowered car (with stock 19x9.5 et52 wheels) will result in a very small poke, so 12mm or even better 10mm rears spacers (for et42) would be better.
Old Jan 4, 2017 | 03:28 PM
updog's Avatar
2014 e63 sedan
forgot to ask, any suggestions on the brand of spacers? Looks like a number of manufacturers (including H&R) don't make them for both front and rear. Would appreciate any suggestions!
Old Jan 6, 2017 | 01:58 PM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
ECS tuning has quality spacers in every mm increments.
