knocking sound, left front suspension
getting so damn tired of this car and its issues....now for past week ive got a knocking sound from front left suspension area....completely different from my previous groaning sound of the strut cap bearing i had previously documented
this is best heard at low speeds and just sounds like something is look and hitting something else....the drive and feel of the car seems normal
i dont know if this is something as a result of the dealer changing everything around a month a go when they were trying to sort out the issue
could it be tires...i have severe inner thread wear on my fronts which i will change befor e i heard to the dealer so they cant blame that...if its not the case.
You need to calm down---have you bounce tested the car---have you put the car on a lift and tried to duplicate the low speed sound\location---have you bla bla instead of whining for help---what have you done!!
Not whining about this bro.. . I'm in process of looking into the possibilities. I've got an appt Tuesday at dealership.... Just annoyed
Received 2,032 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Taking mine in Tuesday for yet another airmatic malfunction ... lovely
so my current Mich PSS have 26000 miles on them. the rears have 5/32 left, but the fronts were worn badly at the inner side......i had my old P0's in the shed from the fronts....they were still quite good at 18000 miles but the rears were bald so saved the fronts.....
so before going to dealer i decided to change the fronts to the old pirellis, first to make sure that it wasnt just a tire issue because of bad fronts with the PSS, and second to make sure the dealer doesnt say " hey u got worn tires, change them before we work on car, safety liability etc etc"
well after putting the pirelli back on the noise persisted, so that ruled out tires....
so they first did left lower steering knuckle joint replacement 2123300135 and tubular torsion bar 2183230465
according to their paperwork that didnt work, then they replaced front sway bar...
Omg
E63s
All the parts they changed I'm surprised the noise is still there, It must be something stupid there looking past, Is it a rattle sound or a knocking sound ? I know this is a long shot but did they check the spring tension on the front brake pads that can make a loose rattle sound if faulty ?
im not surprised.....its like should i goto another dealer instead....but i dont want to give them that satisfaction...
ill check on the pad...
its a knock....undulations or road markers will make it happen....its not as bad as it was when i first dropped it off, but even then it had progressively gotten worse...ill probably take it in next week....car still drives fine though....so it seems
well found this thread, its more apt to my reply i posted in my "groaning noises" thread
yeah so reading thru this one..not sure how it ended back in 2017 January , but yeah knock is back, and recently really worsened
15000 miles is all they last? the rubber looks good, no signs of grease leak but i havent removed from car to properly assess...hopefully its nothing worse
thanks
thanks
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
I fought this battle for months....
and now I can't recall what the part number was that we replaced. Seemed to do the trick. The bushing at the end of it looked iffy, at only 29k miles.
Lemme find the PN and the description....
3 words: Left Front Strut
I had a knocking noise when hitting a speed bumps just right (not fast or anything). They replaced the strut and it was fixed. That was over a year ago now. Still fine.
You might want to check this.
Good luck.
Good luck.
thats what i hope it isnt
as im outta warrenty and u cant buy new ones
my last warrenty item before expiry was the right strut but never got explanation as to what it was problem wise specifically. That sound was different to what it is now. so tired of this ****
Bushings
I had a clunking noise at low speeds. Mostly when turning left into parking spaces and reversing out of them in either direction. Took it to the dealership. They replaced the left front bushings on the control arms.
I've had this problem twice but both times it was separate issues. The first time it was a TSB for an upper (and lower IIRC) control arm and the second time it was both strut tops.
