Roll Racers please come in! Also Logged runs need input.
Old Jan 20, 2017 | 12:54 PM
TTMerc's Avatar
2014 CLS63 S
Had a bunch of roll races in Mexico last night. What do you guys use technique wise? Sport? Sport+? Manual? I was using Sport and down shifting to 3rd then waiting for 3rd honk and letting it shift. Is there a way to make it stay in Sport manual mode longer?
Also I have Question on a tuning aspect. I have my inter cooler pump on a switch Full on/Full off. If I have it on it makes way less boost but adds timing. If i let it get hot (120F or so) it makes more boost less timing. Anyway to have both? Will a tune fix that? Here is a couple graphs from the runs. Only mods are Catless/resonator removed, K&Ns. Modded intake. Every run was different not consistent at all. Gas was 93. May have had some bad gas?? Any input would be great!
Roll Racers please come in! Also Logged runs need input.-run3_zps0e5o8nu6.jpg
Roll Racers please come in! Also Logged runs need input.-run1_zpsvofbuonk.jpg
Roll Racers please come in! Also Logged runs need input.-run2_zpstnk95kmh.jpg
Roll Racers please come in! Also Logged runs need input.-vetterun_zpsbyl6atye.jpg
Old Jan 20, 2017 | 01:46 PM
kponti's Avatar
E63
Seems relatively consistent to me. That last run seems you let off and back on a couple of times and its reflected in the other parameters jumping around
Second to last run you let off kinda early, but not all the way off.
Also use sport plus for all roll runs. Your boost may seem lower (if it does) but you put out more power to the wheels
Old Jan 20, 2017 | 07:43 PM
2012 CCB E63's Avatar
2012 E63
Sport +
Hold the downshift paddle at your pre roll speed
The car will automatically put you in the correct gear for maximum acceleration.
Old Jan 21, 2017 | 10:51 AM
TTMerc's Avatar
2014 CLS63 S
Thanks guys! I know the holding down trick but does that also keep it in manual mode longer? Also does traction in Sport or off work any better/worse?
Old Jan 21, 2017 | 11:03 AM
iownedu's Avatar
2014 Mercedes E63S AMG
I leave traction completely off, if you get some wheel spin it will completely bog out with the traction control on.
Old Jan 22, 2017 | 12:28 AM
Amg63-'s Avatar
CLS63 AMG
Just put traction control on sport handling mode. Especially if your AWD chances are from a rolling start you will not slip enough with car in sport handling mode for traction control to kick in and cut any power.
Old Jan 22, 2017 | 09:56 AM
kponti's Avatar
E63
Agreed with leaving TC all the way off. I did some random tests and even with launching, there was a significant difference in how the car accelerates with traction control on or off.
Vbox seem to indicate better acceleration with traction control all the way off vs sport mode, this despite more wheelspin
Old Jan 22, 2017 | 12:43 PM
TTMerc's Avatar
2014 CLS63 S
That's great information! Thank you! I'll make sure its off!
