Anyone know what these are?
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
they are wear indicators, dont take them off...When the pad wears down to a dangerous level the indicator will scrape against the rotor and will creates a loud annoying grinding noise to warn you that current pads are in danger of basically eroding away altogether. All of our rear pads will have them (my EBC red stuff has them as well as the oem's i replaced)
i also think i would make it more chattery if you remove them
raudiace4 (02-08-2017)
*edit: those can't be wear indicators. Indicators are usually just a single tab of metal facing the rotor, these are two pivoting rockers sticking out of the top of the calipers.
from what I remember only sensors in the front, the rears rely on mechanical indicators. And these ones work in a different way than the old ones you're referring to. When the pads wear down too much these will hit since they oppose each other on each side of the caliper ... I believe the metal tabs are on both sides now to keep them true and from biting into the calipers too much and ruining them... also it accounts for uneven pad wear where as the old indicators on just one side would not account for un even pad wear between inner and outer pads
Wow, google is getting to be way to intrusive. After a quick google search, I immediately get an email for brake pad offers.
I'm pretty sure we have one electronic sensor for the rear. Also, I don't think there's any way these could ever touch the opposing side even with complete pad wear. I think they have to be some sort of vibration dampening attachment but I just want to know for sure befor I remove them.
These are all a bunch of good guesses, that's for sure!
I can tell you that the pads from http://www.racingbrake.com don't have that feature on them. I just installed front/rear rotors and pads from RB. Here's a pic...not sure if you can tell or not:
it was bugging me that i couldnt find anything definitive on what their true function is so kept searching and finally found answer on rennlist... they are harmonic counterweights for squeal reduction...
first time i have ever seen them was this brake change (also the heaviest pads i ever felt, go figure lol).. one thing i know is they were handy for keeping the anti squeal compound off my hands and pads during install as they made a nice handle
I wonder what it was about the OEM pads that made them squeal, and therefore, made the OEM add these weights? The RB pads, w/o a counterweight, haven't made a peep in the ~1,000 that I've had them.
While I'm at it, here are a few pics of the RacingBrake rotors/pads:
E63s
Harmonic dampeners are cylindrical on the front pads and trapezoidal on the rear pads,there suppose to help with brake squeal/vibration , We have brake pad wear sensors on the passenger side only , I changed my pads and sensors the sensors are only about 5 bucks each to replace but you can use the old ones if you didn't go low to give you a warning light , My pads are Centric posi quiets there at least 50% less dust
E63s
Do you have any brake squeal ?
Hiow bad is the brake dust ?
Did you get the oversized fronts ?
Can you post more pics of these please ,thanks
Pics are above. Enjoy!
* No brake squeal.
* 99% less brake dust. (my OEM pads/rotors were THE WORST with brake dust. It was friggen embarrassing, honestly. The RB combination is 100% acceptable as far as brake dust is concerned).
* These aren't the oversized rotors. It seemed like overkill.
* Also, I had the car in for the 40k service at the dealer and they flushed the brake fluid (that was about 4k miles ago). And the brake lines are stock, too.
With all that said, I'm completely happy with the RB setup. The initial bite of the brakes are nice and smooth, making for nice around-the-town action. As you put more pressure on the brake pedal, the bite increases progressively until your, like, "holy cr@p, these brakes are serious!" I've had a few oh-shart moments where I've had to stab the brakes and they reacted instantly and predictably. I highly recommend this setup if you're in the market for rotors/pads....as good or better than stock, for sure.
* No brake squeal.
Well that answers both my questions. RB pads/rotors will be on my short list followed by 17" rims and drag radials for the track. Thanks guys!
E63s
* No brake squeal.
* No brake squeal.
My stock rotors are ok but in some spots there is rust spots on the hats , I really hate that ! I don't know why they didn't put 2 peice rotors/ floating rotors on in the first place ? Friggin Mustangs come with them now lol, having the aluminum hat is a huge bonus for me as well , I'm glad to hear there working good .
If you get a chance can you post some pics of the setup off the car before install if you have any , Or even some on the car , Thanks again
Can you please take a pic with better lighting on the rear pads/calipers?
