Auxiliary battery malfunction
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
Just started today... taking in next week for A1 service anyways ...
do they replace it if it's bad? Is this the trunk one?
Yep, sat for a week, but drove it a couple days and no problems then today with the message? 2014 with 17k miles ....
edit: tonight no message warning ... weird
Peter-Had that malfunction as well-Dealer told me aux battery was primarily for the start/stop function (Same as your dealer). Incidentally, Im due for A1 service as well. Was quoted $700. Is this possible?
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
I have heard there is another battery below the steering wheel location. If it's the battery in the truck, it should be an easy diy because it's easily accessible.
My in service date dec 2013; I can't imagine paying $700 for that!!! Will definitely try to get them to cover this under warranty
thanks for all the info
I just had my 20,000 mile service done, and it was $339 + tax. I paid extra for cabin filter and diff fluid change.
They also fixed the front grille whistle under warranty.
As mentioned above my aux battery is behind the cover on the driver side of the dash that is normally covered with the door closed. But i have a 2010. So not sure if it has changed locations. Very easy to swap. Battery is like $50-75 i think. Don't remember
Aux battery was replaced under warranty, $197 to check/test and then replace, I paid nothing. A1 covered under my service plan. Didn't have them do the adaption because quite honestly my car is running smooth and I didn't want to mess with a good thing, I've made that mistake before
100% warranty
Kinda lame that parktronic and presafe stuff stops working when that battery does?
On my way to the dealer and the warning went away. I believe all dealerships have some sort of symptom canceling force field to temporary disable any issues you have with the car when entering the service center lol.
There will be stored faults. They shouldn't give you a hard time about it, the batteries are relatively cheap and they fail very often.
yup... all rattles and creaks get cancelled too... and any vibrations
Booooommmm......I read the post and get the error message.....90 mins later problem is solved by the dealer at no cost under warranty. Now only if we could turn ECO off by default, I think this would be less of an issue!!!
