E63 Shift knob upgrade gone wrong
So as most do, i wanted the 2012+ shift knob on my 2010 E63. I talked to numerous forum members, Technicians, etc.
All of them told me the same thing- pull up on the shifter.
So i went to attempt it. Did not twist, did not yank, just gradually pulled harder and harder.
Until this happened
So, the transmission mode select dial got its ribbon cable completely torn, and the pins on the other buttons were heavily bent along with the plastic surround for them getting broken.
The gear selector assembly on the other hand- i pulled hard enough to break both clips holding the gear selector shaft into it's white plastic base. Pieces of plastic were all in the console. I pulled the gear selector assembly apart, found that the board inside looked to be good, and reassembled.
Here's what i got after reassembling.
The shifter had a very "scratchy" feel to it. No more smoothness. It also would pop out of it's base every time it was moved, which in turn made the car switch in between gears sporadically. Both of those issues can be seen in the video.
The shifter popping out of the base, changing gears on its own, i couldn't fix. Im sure i could glue/epoxy it together, but who wants to do that to such an important component.
But the problem was somewhat fixed, after locating this little lubricated ball bearing in the bottom of the console. See here- before and after- without and with the part reinstalled.
So at this point, the shifter felt correct but still popped out of the base.
I located the trans mode select dial, all three buttons, with the console bezel still attached pulled from a 2010 e63 with 60k-ish miles for a very fair price in the United States. The traction control button was heavily scratched, and that just so happened to be the one button on mine that wasnt damaged. So, i swapped my button into the bracket holding the two other (new) buttons i got.
Then located a whole gear selector assembly with the knob attached, pulled out of a 2012 e63 (new style shift knob) over in Latvia.
After confirming part numbers, getting better pics, dealing with time zone differences, i got it. 2 day shipping from Riga, Latvia to Louisiana. Awesome.
I will say, the new knob has some small dents in the leather, but nothing extreme. Plus, it feels a whole lot more precise than my old shifter. Even the Park button.
I believe, along with a tech i spoke with, that my old shifter was permanently glued on.
It did in fact have some side to side slop to it, but WILL NOT come off. I have even tried removing it now that it is out of the car and it will not budge.
I feel like it may have gotten broken at one point, previous owner said to his dealer, "hey im sick of this thing coming off, make sure it never comes off again"
It did also have a large crack running up the shifter before i even tried removing it. I have tried prying the shifter apart with a screwdriver to remove it- no luck.
So, lesson learned. Could have been a tragically expensive mistake, but i ended up being very fortunate to stumble upon the parts i needed for less than 1/5 of the price from the dealer, and being able to speak with the correct people to lead me in the right direction. My car is 100% back to normal now
This just goes out to anyone wanting to do this upgrade. I don't want to scare anyone off, as i think the shifter was worth it in the end. Looks and feels miles better.
Just wanted to spread some info. My case hopefully won't be like all you who try to do the upgrade.
P.S.- I know where a brand new one of these new style shifters is. Never opened from the box. I was going to purchase until i located the whole assembly in Latvia. PM me if interested.
so do u have a 2nd set of the 3 buttons....id be interested in just the amg button if u do have a spare set. let me know,
thanks
So as most do, i wanted the 2012+ shift knob on my 2010 E63. I talked to numerous forum members, Technicians, Hell even an AMG tech and the shop foreman of a massive MB dealer.
Until this happened
Attachment 362295
Attachment 362296
Attachment 362297
Attachment 362298
Attachment 362299
Attachment 362300
https://www.youtube.com/watch?v=lCPjC53WnEk
Attachment 362301
Attachment 362302
Attachment 362303
Attachment 362304
Attachment 362305
Attachment 362306
Attachment 362307
tks vm
Are you positive it just comes off if pulled hard?
I also have a crack on mine.. I wonder if the original owner also glued it?? I kinda want to try to pull it but now I'm afraid to break it. How hard did you have to pull to break it off?
Anyone else replaced theirs by just pulling it off?Eyad
Just pull on the old shifter knob with 1 swift pull, you do not need to use all of your strength to pull the knob off.
I have a brand new knob at home for sale that I was going to dye the black leather to red, but sold the E63 before I could get it done.
Brand new Mercedes OEM knob for sale: $550 plus shipping, paid $799 plus tax.
As mentioned, I have remove ( not the knob for sale ) and installed the shifting knob a few times and you do not need to be a weight lifter to remove it. You can see from the photos below, the plastic clip ( gray ) in the center of the knob where the actual shifter goes into is a plastic clip that snaps on and off with a short upright pull. It’s that easy or you can pay an Indy shop do it for $50. It’s a great upgrade for the 2010-2011 E63 IMHO.
However, it is also possible that they know another trick or just the right way to secure the base assembly while giving the knob a good yank. Could be a tribal knowledge thing here. But those tangs suggest otherwise to me. And yes, the lead-ins on the tangs might just be for pushing the knob on.
Hahahaha no it's all good. I laugh about it now as well. I'm not a weight lifter but I'm a pretty big guy. I've broken many things from using too much force sadly. Where did you get those seat buttons?
Could you let me know what sources you had for replacement shifter parts.
Really appreciate it.
