Anyone know what this Is/Does on the intercooler?
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
weird, i found it on russian parts diagram but not on north american parts diagram... its a vent line.. part A2780106001
Well what brought me to this part is the fact that I haven't seen it on many other intercoolers I've seen in pictures or in person. That makes me wonder what it is and why mine has it and others do not. It looks like the diameter is a bit small for a Dump valve/ Blow off valve but the positioning would be perfect if I could make an adapter with BOV instead of welding a BOV on a factory charge pipe. Even welding one on, there's no a lot of space anywhere to do that. Hope that answers your question
Former Vendor of MBWorld
We use that as a pressure port and measure boost there on the dyno. We had to make a special aluminum fitting to go into it but it is a port for air. I was going to make a water injection kit that goes into that port but not all tt 5.5 motors have that nipple.
TTMerc (03-04-2017)
Thanks again!
We use a needle nose plier to move the lock out of the way that I will describe as a finger that holds the piece in place and then I use another plier to turn the actual piece and remove it. The port is large and you would need to make some type of adapter to use it.
We machined an aluminum piece on our lathe that we attach a vacuum line to so that we can get a boost reading for our dyno.
