Factory shift points wrong for tuned E63s
E63 shift points are fine on stock tune since power doesn't drop off, but turns into a problem when the small turbos get tuned and can't hold power strong to redline, yet are still "stuck" running on stock shift points.
With that said, e63 still has the torque advantage and depending on how both are tuned and which speeds either one can be quicker it all depends.
Some of the tunes also seem to make more power near redline than others so with some of them stock shift points still work very well and effectively on tuned m157s while for others it's worse.
I tried shifting just before 6k as expected I went backwards instantly from 3rd gear above.. for my car this doesn't work anyone who needs to shift like a diesel should probably look at there tune
https://youtu.be/Xt23q64FaHk
So after my EC tune, I think I'm hitting the rev limiter in S+ mode.
In S mode (and S+ prior to tune) - super fast shift, smooth, and linear pulling
In S+ mode After tune - it feels like I'm attempting a 2Fast2Furious power shift or something with the gas floored. The shift is slower and it is ROUGH. At first I thought something was broken but now I'm just kind of convinced that I'm hitting the rev limiter because it doesn't happen with paddles.
Any of you tuned guys run into this? In the good ol stock days, I could just floor it in S+ and it magically ran through the gears smooth as butter. Now it seems like S or Manual is more ideal
they had to regap the spark plugs becsuse at first it was misfiring at WOT.
Tell them regap plugs to 0.21 and take it from there.
Maybe you can get away with manual upshifts on the N/A E63 bc it's slow anyway.
It was night and day better after that and now S+ just makes me feel like I'm hurting the car. I feel like it's time for some sweet shaky blair witch cell phone videos to show you guys.
Maybe I'm just not used to the rougher shift - it just doesn't feel as snappy as S.
You had legit misfires happening though right? Did it just feel down on power? What were the symptoms?
Im not saying to change to different plugs. Use OEM but just get hem regapped to 0.21. Tell them to try it. They can contact EC in Toronto to get some details on the job.
Here is my tinfoil hat conspiracy theorist. Do you think that Mercedes sent out some of their early models more aggressively tuned to the magazine folks to garner better reviews? Because I have a hard time believing anyone thought the S+ mode was rough prior to tune.
- the car is no slower in S mode, compared to S+mode, or at least I've proven this to myself on the drag strip...so, if I want immediate shifts, I drive in S mode and go pedal to the medal
- i mostly drive the car in M mode on the street, since I like the fact that the car won't upshift without my request...but again, if looking for best upshift times, S does it for me
- feels like S+ is there to give us the feeling that the car is making brutal shifts, when in fact, it's manipulated, and less than efficient
In response to your tinfoil hat conspiracy theory, this would not surprise me at all...we've all seen 0-60 times, etc, that are quite hard to replicate...this goes for manufacturers and tuners alike...some, but not all of course
