Can I fit 305 or 295 tire
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
My bet....
Is that the 305 will interfere a bunch...especially if you're lowered. The 295 may interfere, but depends on the brand, wheel width and offset. Not automatic on either of them. And spacers aren't going to make it better, probably worse...
Just my 02 cents from lots of experimenting...
W203 C32 AMG...W221 S63...SOLD...W212 E63 CURRENT
Originally Posted by chiromikey
Those widths will fit as long as the wheel has the correct offset.
Originally Posted by RJStanford
Yup. 295s in a variety of brands is fine. I've had Michelin Bridgestone and now AD08R and they're all fine on the 9.5
If you're doing fronts, The 265/35 is a good match for the 295/30 - Yokohama discontinued that size in AD08R unfortunately so I've gone 275/30 and that works well too with minimal ulge. There's a surprising amount of space up front, tons of strut clearance.
I'm running 305/30 and 265/35 and the tc nannies in the ecu do not approve. I'm going to have to run 275s in the front or go down to 295s in the back
Just installed the new Michelin Pilot Sport 4S on the stock rims of my 2015 E63S.
263-35-19 fronts and 295-30-19 rears. No rubbing and much smoother, grippier, quieter and wider than the stock Pirellis wich were shot after 10K miles.
Very happy with this combo !
