Are you guys really running 50psi in tires?
Old May 1, 2017 | 12:06 AM
vikingdiesel's Avatar
15 S63, 18 Ram 2500 Cummins
My 2012 E63 tag on the door shows I should be running 51psi of air, isnt that way too much? What are you guys running on your stock wheels? I have the stock 19"
Old May 1, 2017 | 01:28 AM
CliffJumper's Avatar
no MBs at the moment :(
My car (2016) has a wrong (maybe for an E350?) tire pressure sticker on the door where all other cars have it, but the real one for AMGs is actually inside the fuel door. Very strange, but comes from the factory like that.
And no, not 51psi. 41psi with low loads and lower speeds.
Old May 1, 2017 | 02:47 AM
PeterUbers's Avatar
42
Old May 1, 2017 | 07:42 AM
Celicasaur's Avatar
W212 - E63 AMG
i run 42
Old May 1, 2017 | 01:48 PM
arcticfox's Avatar
2020 E63S
I run at 43 on Pirelli P Zero's. Commute route is full of nasty pavement, so I put a few extra PSI in the tires.
Old May 1, 2017 | 02:36 PM
Wickdwagon's Avatar
04 E55
Ok, maybe I am slow...but why would you not run the poundage that is on the door tag?
Old May 1, 2017 | 02:55 PM
Jimminez's Avatar
2016 E63 S AMG
Not sure if its the same on your, but door tag lists the max tire pressure while the gas cap has the recommended pressure based on speed and load. I found this strange as it's the first car I've owned that doesn't have the recommended pressure on the door sill of the drivers door.
Old May 1, 2017 | 02:57 PM
Jimminez's Avatar
2016 E63 S AMG
And I'm currently running 42 front and 44 rear in my wagon with the 20" wheels. Often I have more than three and stuff in the trunk which suggests higher rear, and with the lower load rating of the 20" tires, I added 1 psi.
Old May 1, 2017 | 05:27 PM
10speed's Avatar
E63s
I'm running 40 front 38 rear cold goes up a few ponds when hot , I'm not using nitrogen , are you guys using nitrogen ???
Old May 1, 2017 | 05:37 PM
Jimminez's Avatar
2016 E63 S AMG
I do not and don't subscribe to the nitrogen in passenger cars theory.
Is 40/38 what is recommended for yours? Seems low.
Old May 1, 2017 | 06:07 PM
Silverp30wagon's Avatar
2012 E63S Wagon, 2005 E500
I'm running 43 front and 47 rear in my car. I often break 100-120 mph and almost always have at least 3 in the car plus stroller, etc.
Old May 1, 2017 | 06:12 PM
10speed's Avatar
E63s
I took this pic awhile ago , I go by the top line I guess if I'm going to drive186mph I will go higher lol but I will stick with 155mph for now lol This is on my fuel door.
Old May 7, 2017 | 12:58 PM
so realistically Low 40s in the front and mid 40s in the rear
Old May 7, 2017 | 01:00 PM
AG6's Avatar
AG6
13 GL550
42
Same here.
Old May 7, 2017 | 07:35 PM
izzy63's Avatar
2013 C63
40 Fronts/42 Rear
Old Apr 15, 2026 | 11:56 PM
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
so what is the max M+S designated for?
Old Apr 16, 2026 | 12:31 AM
BDC90's Avatar
2014 E63 AMG wagon 1965 Austin-Healey 3000 1970 AMC AMX
I guess MB doesn't want You going faster than 149 mph in a blizzard.
Old Apr 16, 2026 | 01:30 AM
so it means it’s for snow?
Old Apr 16, 2026 | 10:53 AM
BDC90's Avatar
For M + S rated tires which I always thought meant mud and snow. Might be a generic AMG sticker that applies to G wagons too.
Old Apr 16, 2026 | 12:17 PM
Hmm I wonder the same.
Old Apr 17, 2026 | 11:38 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
I run 43/43 with my Conti DWS06+ tires. Same as i ran with the P Zero tires.
I run the same pressure with my Nokian winter tires.
