"Auxiliary battery malfunction"
Thanks for the help....sorry for the ignorance!
It also provides supplemental power if the main battery voltage is low
The trunk battery is used in conjunction with the eco-stop logic to help maintain system voltages during engine-off situations and on re-start.
They do fail all the time, they have an internal resistance check that fails and you get the message. Usually the battery will still show 12.6+ volts and be ok, but as soon as it gets at all worn the car wants it replaced.
