AMS 722.9 Performance Frictions Clutches - Thanks Shardul and UPD!
Make sure you are changing trans oil after first 500 miles use after new clutches install
There are lots of break in material from new clutches that can block the solenoids
Ultimately transmission tuning is also required for high performance automatics to ensure enough line pressure and clutch to clutch transitional shift pressures are sufficient to keep from slipping clutches and burning them up. This is common in the GM 6l-8l 80/90 platforms, where you have the like of HP tuners allowing you to modify those parameter. I think on the 722.9 platform we are kind of screwed until the SW tuning catches up with HW.
No matter what, making an automatic clutch to clutch type transmission live with more than 1000ft-lbs is always going to be a challenge. No such think as bulletproof in our world.
