Quirky M157 engine questions....
16 E550 Cab, 2003 Ram bright red crewcab 4x4 we call Clifford :)
I tried asking in the ML63 (W166) section but got a big goose egg for responses. Lot more traffic here, hopefully you guys can shed a little light
Just picked up a 2012 ML63 Friday, it has the P30 package as well, I'm new to AMG so be gentle... This is a M157 engine according to the wiki , not sure if it's identical to an E63 but thought it may share some characteristics....
Couple of things...
Seems to be slow to start, aka it doesn't turn over too fast but so far it has always started... normal ?
Little rough when cold, I live in South Florida, so not winter cold.. in a few minutes everything smooths out.... again normal ?
Mike
Couple of things...
Mike
I have a 2012 E63 with 36K miles. Starts pretty quick, maybe 1/2 second.
One time it took maybe 1.5 seconds, not sure what happened there.
Pretty smooth from start from my experience.
Maybe you need plugs? How many miles are on yours? When and what was the last service?
ok slow start... kinda like a car with high compression.... turn the key you can hear it move slowly then i guess the spark hits and it kicks over with a roar... i don't think it turns a full revolution... I'm used to the E550 that starts immediately...
almost like a weak battery ... which maybe it is but want to make sure it's not normal before i pull out the multimeter and dig in under there
It's a 2012 Ml63 with 29k miles on it...
carfax shows....
2 battery replacements and an alternator over it's short life...
I may be able to attribute some of that to Florida Heat... seems to kill batteries and maybe the alternator got blamed...
From your replies though it doesn't seem like a quirk of the M157, will check myself with a meter before i bring it in... I like to know the answers before i ask them the questions...
Thanks Guys
Mike
carfax shows....
Thanks Guys
Mike
carfax shows....
Thanks Guys
Mike
carfax shows....
Thanks Guys
Mike
Battery is at 12.85, when you start it voltage hovers around 13.7... so pretty normal....
Went to the dealer and the tech say's it needs a new starter.... hmmm 2012, 29k miles ? it's already had a new starter...
He mentioned something about if it sits for a long time.... i can buy that with a battery but a starter ?
Mike
