2012 E63 AMG dyno results with vid!
Old Aug 19, 2017 | 08:39 PM
Izar90's Avatar
E350
So I bought this 2012 E63 amg biturbo p31 package, owned for cupel of weeks now, I decided to do an dyno run, 4 gear pulls no traction each time, so in 4th gear with lots of wheel spin it made 583whp and 654tq and 5th gear pull It made 591whp and 708tq, But as far as i know the car is fully stock, 85+ degrees outside temp thsoe numbers was after 3 pulls !
How can i check if the car is stock or tuned?
Old Aug 19, 2017 | 09:00 PM
PeterUbers's Avatar
youre done, it's tuned.
Old Aug 19, 2017 | 09:32 PM
M-Theory's Avatar
M3
The numbers alone say it's tuned 100%, throw some down pipes on and get the rwhp in the 600's.
Old Aug 20, 2017 | 01:02 AM
Mikeki7's Avatar
CLS63, S55
Look at your ecu, should be a plug inside of a drilled hole. Some tuners will use heat and open the casing instead but you are definitely tuned. You can also email various tuners and ask them to check with your vin number.
Old Aug 20, 2017 | 12:20 PM
PeterUbers's Avatar
Did you buy it cpo from a benz dealer?
