Stealing Mercedes
2014 E63s 1993 mazda rx7 on Boost
look like a signal amplifer
One guy come to the house to pull the signal from the key inside that is inside the house. ( my thinking) The second person at the cars quater panell ( where all the RF stuff is ) has a transmitter that receive the signal from the first guy that is close to the house.
So now I am thinking our keys is always broadcasting a signal, which make sense.
My doors are locked I walk to the car not touching the remote put my hand next to handle and it unlock. Is the remote broadcasting or is the car broadcasting.
What ever is it this is not good. I had Rx7s and my Grand National all stolen out of my driveway and now this is the last thing I want to see.
As a
As a
Received 1,467 Likes
I suppose you could stick them in those anti-static bags to stop them from transmitting.
My friend said I should make lead boxes design
for storing keys. ( superman style)
So does this mean that the keys are transmitting a signal all the time. I guess remove battery from spare key is a start if this is of concern to owners.
A lot of cars being stolen in the UK like this, BMW`s M`s, Merc`s, Audi`s
Anything keyless! use a metal box or lined bag to stop this happening
Another method is breaking into the house and stealing keys, probably the uneducated smackheads doing it this way!
The foil did the trick
I wrap my spare in foil.
I will look into a lined storage box for my daily keys. All cars are keyless-Go.
I guess a fix will be coming soon and that will decrease our remote range I am sure of it.
Received 1,886 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
best way to test if your box or bag is working is to try opening the car or starting it while the keyfob is in the box and in your possession as you try to open or start the car
Have you tested the range of your key fob yet? I've done it....my car won't open unless the key is within 5 to 10 feet of the car. Go try and tell us what you find.
They don't need to reduce the range, they just need to increase the security.
My key fob will work through walls into my garage and I remote start across parking lots especially if I put the key fob to my head before pressing the button. Don't know about 5-10 feet, @omega_jeff maybe your battery is low. I believe there are 2 communication methods used by the key. RF signal for long range use and IR for right next to the car for example if you hold the unlock/lock button it will open/close all windows/sunroof but only if you are next to the doors.
The key must always be transmitting a signal but the car only starts looking for a key when you touch a keyless door handle or press the trunk button. Just a guess. I think i forgot my key one time, touched the door handle and the car started to prime the fuel pump/airmatic but obviously the door did not open.
Is Mercedes security that **** that they just "scan" and then can clone a key and turn on the car. That's insane, how is the security that bad or what kind of sophisticated tech are they using to pull this off. Surely it can't be that simple.
Kind of scary because I don't care about the car, it's insured but I sometimes leave things in the car.
For me, if someone is going to go to that much trouble to steal my car, I'm going to let them.
Modern day remotes should be using the rolling code / handshake method whereby each time the remote is used, there is a special handshake done between the two (remote and unit) which need to have identical codes the next time either transmitter 1 or 2 or whatever is used. As well - usually to start the vehicle, the key needs to be inside the cabin... usually. Surprised how they are making off with these cars.
Somebody mentioned it, but yeah - build a faraday cage if you're worried about it. Not too difficult or expensive. https://www.thesurvivalistblog.net/b...age-heres-how/
