WHAT SOUNDS BETTER, RESONATOR DELETE OR X-PIPE FOR MY 2010 E63
Old Nov 7, 2017 | 08:48 PM
e63amg4life's Avatar
x5 3.5d
Hey guys I'm looking to get a little more sound out of my E63, not really over the top just a little more rumble. I just sold my MBH headers because I couldn't pass emissions over here in NY and I put my stock headers and cats back on and it's super quiet. go figure! should I go the X-pipe way or just delete my resonators?
Old Nov 8, 2017 | 10:18 AM
x5 3.5d
bump
Old Nov 8, 2017 | 06:04 PM
10speed's Avatar
E63s
Hi I’m not really sure what sounds better but from what I understand an x pipe is better for NA engine and straight for turbo , I’m in NY as well why couldn’t you pass inspection ?? Headers would be fine ,and for no cats If you don’t have a cel light on it will pass , or they failed you on a visible inspection?
Old Nov 9, 2017 | 10:18 AM
sikm3's Avatar
Black '10 E63
If you want a little more sound, then I would recommend you do both. X-pipe and resonator delete will be a little louder than stock and will give you a satisfying deeper growl at WOT. No droning and the sound is not obnoxious at all. I kept my OEM cats but if you installed race cats I would suspect it would be slightly louder. I did x-pipe and resonator delete and I have no need for it be louder.
Old Nov 10, 2017 | 07:41 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
If the W212 setup is similar to the W204 C63, I recommend you add a crossover in place of the resonator, either an X or H pipe. Keeping the exhaust straight with no crossover will sound like ****, similar to the W164. My ML63 sounded like a boat, 4 separate cylinders on each bank.
Old Nov 10, 2017 | 11:15 AM
sikm3's Avatar
Black '10 E63
And be sure to install the x-pipe closer to the cats.
