Air Conditioning
Old Jun 17, 2018 | 10:28 AM
THXETHAMG's Avatar
2010 E63 AMG
Air Conditioning
My AC had been working and then the next morning I press the AC button and it blinks red 3 times. The low side pressure is very high around 105 when the car is running. I haven't added any r134a, is it safe to connect the can and release the pressure?
Thank you
Old Jun 17, 2018 | 12:09 PM
AMG Rick's Avatar
2012 MB E63 AMG
Thank you
Adding fluid will not solve the problem your system is leaking. If you put any in it will leak out.
Old Jun 17, 2018 | 12:23 PM
g60wall's Avatar
2014 E63s
I had same issue, before I got t fixed input a can of refrigeratant in and it held me over till the repair.
Old Jun 28, 2018 | 08:52 AM
THXETHAMG's Avatar
2010 E63 AMG
The resolution to my issue was replacing the A/C Refrigerant Pressure Sensor (2110000283). Symptom was when you press AC button it would blink red 3 times and go off. There wasn't any leak and I wasn't low on r134a. Easy replacement from under the car. Hope this helps someone else down the road.
