Tilt Wheel Memory Lost after Battery Change
My stock main battery died a few days ago and I replaced it yesterday (had to wait for the replacement to come from Interstate). All the memory functions appear to have been saved (thanks to the aux battery probably) except the tilt wheel.
It properly goes to the most upward position when turning off the car. However, when starting, it remains there and does not return to the preset location.
I tried resetting the memory button on the door with the wheel in my preferred position, but it doesn't seem to be working. Thus, I am manually putting the wheel in "driving position" after every start.
Any thoughts how to restore the memory function?
So, I moved the tilt wheel to max up, down, in , and out positions. I then reprogrammed the memory button after returning the wheel to my desired position.
It appears to have worked. The tilt works as it should.....goes all the way up when turning off the car and returns to the memory position when I start it.
I am not sure if me "reset" procedure did it or something else, but bottom line, it works now.
