Pedal Commander
Old Aug 2, 2018 | 07:05 PM
S63AMG888's Avatar
MY17 S63AMG - MBUSA Buyback. MY16 SL63 - Sold MY19 W213 E63s. 2020 W213 E63s Wagon
Pedal Commander
Anyone heard/used of this can comment?
https://www.pedalcommander.com/?v=7516fd43adaa
Old Aug 2, 2018 | 08:25 PM
K507's Avatar
2018 GLC 63 AMG Coupe
One of the best mods I performed on my F150...definitely works as advertised with no issues
Old Aug 3, 2018 | 03:01 AM
PeterUbers's Avatar
More advanced and programmable than sprintbooster -- I have SB in e63S and am a huge fan
get it from shardul and don't look back
Old Aug 3, 2018 | 06:14 AM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
+1 for the Sprint Booster.
Don't leave home without it.
Old Aug 3, 2018 | 06:13 PM
S63AMG888's Avatar
Thanks for your feedback guys. Anyone happen to know the difference ( pros and cons ) between the 2. Do you just remove it before go in for service ? Thanks again.
Old Aug 3, 2018 | 06:33 PM
PeterUbers's Avatar
The SB has disconnecting programming/controller wire so I leave it for service but you can take ten minutes and remove it; unless they go looking for it they'll never know or care it's there
pedal commander has more than the three sensitivity options ... has about fifteen
Old Aug 3, 2018 | 09:39 PM
K507's Avatar
Pedal commander has 4x9=36 different settings
Old Aug 3, 2018 | 09:52 PM
VirtualRain's Avatar
2016 CLS550 4Matic
I recently looked into it at length and couldn’t find any difference beyond the controller or the number of settings. The SB has a smaller controller. I doubt anyone would find the number of settings a problem with either. Ultimately I decided to put the money towards a tune instead.
Old Aug 3, 2018 | 09:59 PM
Tunes are great too, but it's like comparing apples and oranges.
For ultimate performance you need to do both.
Old Aug 3, 2018 | 11:07 PM
PeterUbers's Avatar
right ...the pedal sensitivity should have been an oem option in the menu system
a tune won't do what a $250 SB will do
apples and oranges is right; the SB doesn't give you better 0-60, 60ft, or 1/4 mike ... it's about better stoplight to stoplight driveabiity
after countless threads on this very discussion it always comes down to -- just try it and return it if you don't like it
Old Aug 4, 2018 | 01:20 AM
S63AMG888's Avatar
The SB and pedal command are to help with the lag from a dead stop whereas the tune is when that lag drops and the car launch from there.
Old Aug 5, 2018 | 01:13 AM
2016 CLS550 4Matic
In a few different threads I came across owners of SB or PC that found them unnecessary after a tune and were selling them. I did find the odd one who kept it after getting a tune. My understanding is that most tunes can adjust the throttle response (which is all these things are doing anyway). I guess my suggestion would be if you ultimately want a tune, get that first and if that’s not enough on its own, get the SB or PC in addition. If you have no plans for a tune or see that way down the road, get a SB or PC as an economical way to get more response.
As someone pointed out, both offer a money back return policy that makes it pretty easy.
