anyone with experience putting 20" s63 wheels on their e63
2018 E63S AMG
i have a 2015 e63s, thinking about upgrading to the s63 20" oem wheels. let me know if this can be done, does it just fit?? need your help
2018 E63S AMG
i am leaning towards the first rim up there, wondering if I can do 20x9.5 all around
Style: 10 Spoke
Finish: Powder Coat Black or Grey Polished
Lugs: 5
Bolt Pattern: 112mm
Offset: 39mm
Option Code: 647, 648
Indents: 2224010700
OE Part Number: 2224010700
Style: 10 Spoke
Lugs: 5
Bolt Pattern: 112mm
Offset: 39mm
Indents: 2224010700
Style: 10 Spoke
Lugs: 5
Bolt Pattern: 112mm
Offset: 39mm
Indents: 2224010700
Style: 10 Spoke
Lugs: 5
Bolt Pattern: 112mm
Offset: 39mm
Indents: 2224010700
2018 E63S AMG
this is so hard to understand and get right, i want to make sure i have everything perfect before ordering. Can you guys recommend tire sizes if possible and shud i roll my fenders?
265/30R20 on 20x9" ET33
295/25R20 on 20x10" ET45
Above are the specs to a very good looking set up. I copied those from a forum member who has a very nicely dialed in wagon (Jimmyness on here). Perhaps you should go the custom wheel route and order a set with those specs. It might cost you about the same as going brand new OEM.
2018 E63S AMG
i am getting a set of oem wheels for free my choice so using it to my advantage, $2400 per wheel forged as well so i would love to put together a setup with them. I plan on running some custom wheels as well already on order.
fyi I go to car shows alot.
Stock setup is 19x9 et37 fronts and 19x9.5 et52 rear ( I might be a mm or 2 off on the offsets but won't matter for what you are trying to do).
i ran stock sized tires and also ran 10mm spacers all the way round with no issues. I took the spacers off and ran 265/295 tire combo and felt like I lost a lot of offset (wheels and tires look sunken in). This is despite only effectively loosing only 5mm (total sink in was 5mm).
I can still run the 10mm spacer upfront with my wider tires with no issues, that's like running a 19x9 et22. However I am not sure if running the 10mm spacer will work on the rear with 295 wide tires.
You can easily extrapolate from above info that the 20x9.5 et35 will easily work upfront depending on tire width and aspect ratio. The rear will be the question, will definitely work but only if you size the tire properly.
2018 E63S AMG
test fitted these s63 20" wheels today
front you would need a 5mm spacer
back fits perfect, i mean perfect.
HOWEVER I decided to get a new set of 19s stock e63 wheels and new pilot super sport tires and then getting my show car set in 3 months more than likely Rohana or HRE. see the pic below of what i decided on
Weekend/Project - W204 C63.
Do you think the first rim would fit? I am interested in putting a set of S63 wheels on my E63s as well. Found a local member parting their S63 rims with tires. Tires I can probably get but the rear rims is what I am worried about. Any insight will help!
I think it depends on the look you want in the end. Meaty tire or stretched tire? I choose to go the meatier look when I went with 20" As @Rehabguy said, I have/had:
20x9" ET32 with 265/30R20
20x10" ET45 with 295/25R20
Depending on how tolerant you are to rubbing, I'd say you could go 5mm more aggressive if you wish.
Received 2,141 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
I think the 19" twin spoke forged look way better than those s63 20" rims
