Please someone help me... Code P2629
I had my CEL come on, m156 amg ran too rich, changed the pre cat sensors which were causing the issue, I replaced both for 2 new ones.
Now the car is saying:
0563 - G3/3 (left o2 sensor before TWC (KAT)) : Open circuit (P2629).
Has anyone seen this problem before?
Could the wiring harness be melted from the exhaust or anything?
Could it be the new o2 is faulty?
could it be the wiring harness or the plug pin?
I hope someone has the answer for me..
Im really stuck in a rut with this e63 amg m156.
Got my new o2 sensor pre cat today, if anyone in the future have this issue i may narrow it down for you.
If its wiring harness issue will post that as well.
let it idle and if you are handy pull the plugs on that bank and look if one of them is really bad and that will be the injector with the issue. I would change all 8.
More info on this issue here:
https://mbworld.org/forums/c63-c63s-...mg-2019-a.html
How many miles on the car might need plugs anyways.. before you change plugs if you do.. Clean the TB first and intake with old plugs on and swap our plugs if you decide to change them.
