S212 / W212 E63 & BBS LM...
Old Aug 30, 2018 | 05:38 PM
iconoclast's Avatar
Audi BMW Ferrari MB & RR
Does anyone on here have this set up?
If so any photos and fitment details?
Thanks.
Old Aug 30, 2018 | 10:29 PM
Jimminez's Avatar
2016 E63 S AMG
A few options but some are Japan only so require special order.
Fronts
19x8.5” ET32
19x9” ET42 would need spacers IMO
Rear
19x9.5” ET38
19x10” ET50 spacers not needed but could use 5mm.
The first from each would run stock tires.
The second 265/295 combo would be money.
I’d need to double check front clearance of CCB though.
20” options aren’t as good as rears would be 20x10” ET38 and a bit aggressive.
just pm me next time so you get a faster reply
Old Aug 30, 2018 | 11:54 PM
Grayblack's Avatar
18 E63S, 22 etron GT
I’d love to see these on the W212. I have E88’s on my M3 and love them.
Old Aug 31, 2018 | 07:59 AM
iconoclast's Avatar
Thanks for the help gentlemen. I appreciate it. I have a feeling sourcing these will be an issue.
Old Aug 31, 2018 | 09:46 AM
Jimminez's Avatar
2016 E63 S AMG
There is also a 19x9.5" ET32 that would fit on the rear but would be aggressive. 6mm more than my LM-R.
8.5" ET32 and 9.5" ET32 are in stock in diamond silver.
20x8.5" ET38 and 20x10" ET38 are in stock as well. 5mm spacer and 255/30 and 285/25 would work but I have a feeling you're looking for 19", right?
Now I know that you'd like the LM. LM-R are an option as well or a custom multipiece wheel that looks similar to LM (but I'm pretty sure of that response),
But I also have my CI-R that I'm taking off to install Volks so that's also an option if you want.
Old Aug 31, 2018 | 10:11 AM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
I thought I had recently seen some new part numbers from BBS on the LM. They used to have a 20" fitment, but had then gone into a posture that they didn't think you should use them on 211, so they dropped them. I don't know what their thinking is now. Having been a BBS dealer many years ago, I can tell you that those kinds of "'mood swings" were not unusual..
That being said, I am down with a set of 20" LM.s , so if someone sees a glimpse, let me know...
Old Aug 31, 2018 | 11:20 AM
Jimminez's Avatar
2016 E63 S AMG
BBS USA doesn't stock or import many of the sizes that are made in Japan. They can be ordered through a dealer but often the pricing is a bit higher due to the additional cost in shipping if you don't want to wait on a standard shipment and waiting on standard shipments can be months late.
https://bbs-japan.co.jp/en/products/1142/
Old Aug 31, 2018 | 12:07 PM
allenjdmb's Avatar
Yep, you are right, as the discount structure for dealers is not as generous as stuff that is not USA stock.
Still, the most beautiful wheel in the world.
AA
Old Aug 31, 2018 | 12:36 PM
iconoclast's Avatar
Tirerack tells me they can't get them and there aren't any 19" BBS that will clear the factory CCB set up. 20" might. Is this true?
Old Aug 31, 2018 | 12:42 PM
allenjdmb's Avatar
You will need the help of a small BBS dealer to get something like this done. Or try calling them in Braselton and see if they will help you....
Old Aug 31, 2018 | 01:24 PM
Jimminez's Avatar
2016 E63 S AMG
Correct. Just confirmed. Just by a few millimeters though for the 2 piece forced.
I have confirmed that the 20x8.5" ET38 fits without spacer but I'd recommend doing a 5mm pfs spacers and then the 20x10" ET38. These are in stock.
There is a 20x9.5" ET36 option that could work but we'd need to get drawings from Japan and then it's a special order item.
Now I know it's not the same as the genuine LMs, but BC Forged have a very similar style and can be made to custom sizes that would allow to run a proper tire size and be made to have full silver that would look very close. But I know it's not the real deal. Problem is the CCBs. Just trade them with me and it will be all sorted for you.
Old Aug 31, 2018 | 02:18 PM
Savage212's Avatar
2014 E63 AMG wagon
Strange as OEM 19"s clear them fine. So the face of the wheel hits the caliper?
Old Aug 31, 2018 | 02:24 PM
Jimminez's Avatar
2016 E63 S AMG
Due to the forged barrel design, there is less clearance for the outer part of caliper as well as the front. The latter can be addressed with a spacer.
Their 19" cast fit, like the OE wheels do. Some of there forged one piece have different barrels.
Old Aug 31, 2018 | 02:26 PM
iconoclast's Avatar
This is a bit more complicated than I initially anticipated. The other option was doing a custom set of wheels through CCW but I would like to explore all possible options on the original/traditional BBS LM first.
