Wheel Fitment on E63S
Old Apr 9, 2022 | 10:24 AM
Avahdani's Avatar
e63 Wagon
Actually came off 2019 E53
Will this fitment suitable for e63 ?
Rim Specs
Front 20x9.5ET20
Rear 20x11ET52
Michelin PS4 tires
Front tire sizes 265/30/20
Rear tire sizes 305/25/20
Old Apr 9, 2022 | 05:42 PM
Rehabguy's Avatar
E63S
Rim Specs
Front 20x9.5ET20
Rear 20x11ET52
Michelin PS4 tires
ET 20 sounds a bit too low an offset for the front even for a 9" wheel with a 265/30 and 11 sounds too wide at that high an offset for the rear. I have personally not tried these combinations nor have I seen (online or in person) anyone with a W212 with these specs. However, as I have posted before on this forum, you can always make them fit via negative camber/adjustable camber arms, spacers and fender rolling. I don't THINK they'll bolt right on and NOT rub.
Old Apr 12, 2022 | 03:23 PM
brfatal's Avatar
2014 E63S AMG
Rim Specs
Front 20x9.5ET20
Rear 20x11ET52
Michelin PS4 tires
No it will not. Neither by wheel fitment nor by tire sizing. W213 setups don't fit W212 well.
Old Apr 19, 2022 | 07:45 PM
Avahdani's Avatar
e63 Wagon
One more try as I may be looking at a used HRE. However, this is the size and offsets. Will this be suitable for 2016 E63 wagon?
Front: 20x9 ET20
245/35ZR20
Rear: 20x10.5 ET49
275/30ZR20
Old Apr 19, 2022 | 08:21 PM
berti_00's Avatar
2016 Cls63s AMG
I have this but a cls63s
FRONT 20x9 ET20 255/30/20
REAR 20x10.5 ET35 305/30/20
Old Apr 20, 2022 | 04:24 PM
brfatal's Avatar
2014 E63S AMG
Front: 20x9 ET20
245/35ZR20
Rear: 20x10.5 ET49
275/30ZR20
Front offset too low and the rears too high.
Old Apr 20, 2022 | 10:18 PM
  #32
Rehabguy's Avatar
E63S
Front: 20x9 ET20
245/35ZR20
Rear: 20x10.5 ET49
275/30ZR20
As stated above. ET20 is/might be too low for the front. It MIGHT work. The wheel will be 17mm closer to inside of fender and this tire will be slightly stretched compared to the stock 255/35/19.
The rear will definitely work. I run 19x10.5 ET52 w/ 3mm spacer and 305/30/19. No rub whatsoever. No fender mods and I am lowered.
Also. This WHOLE set up is taller than OE set up by 9.2 and 9.7mm respectively. I have read one should always keep the new set up specs as close to OE height as possible in order to avoid damaging trans. Some have said that as long as the front and rear are same height it should be OK for trans.
Old Apr 25, 2022 | 08:01 PM
  #33
brfatal's Avatar
2014 E63S AMG
Originally Posted by Rehabguy
AI run 19x10.5 ET52 w/ 3mm spacer and 305/30/19.
Hooow? There's not even a finger's gap behind the back of the stock wheels.
Old Apr 25, 2022 | 10:14 PM
  #34
Rehabguy's Avatar
E63S
I will quote another member on here. I asked how his 20x10 ET35 w/ 255/30's cleared the front and his reply was: "Even by 1mm. Clear is clear" LMAO!
And I inspect and clean the wheel wells 2X/yr (every time I switch from summer to winter set ups). No sign of rubbing anywhere.
Old Apr 27, 2022 | 06:34 AM
  #35
iChan's Avatar
S212 E63s
Originally Posted by Jimminez
Three variants I've done with no issues, all lowered.
Wheel fit and tire spec are subjective. I prefer little to no tire stretch so what I've run have been more meatier tire sizes with wheels specs.
Variant 1
F: 19x8.5" ET33 with 255/35R19
R: 19x9.5" ET38 with 285/30R19
Variant 2
F: 20x9" ET33 with 265/30R20
R: 20x10" ET45 with 295/25R20
Variant 3 (have camber plates up front that make this rub free)
F & R : 19x9.5" ET35 with 265/35R19
I'd say Variant 2 if you are fine with 20" but if you are looking to stick with 19", I'd do 19x9" ET33 (or 9.5" ET 32) with 265/35R19 and 19x10" ET45 with 295/30R19.
If you showed some pics of the look you like (can be on other cars) then I think people can help provide specs that would provide said look.
Some pics to help show how they looked.
Variant 2
Variant 3
Do you think variant 3 will rub on stock suspension without camber plates? Absolutely love how that sits and have the wheels with same specs lined up but want to check before pushing go. Not planning to lower as I already have clearance issues (have a towbar fitted). Thanks!
Old Jun 16, 2022 | 01:46 AM
  #36
Avahdani's Avatar
e63 Wagon
Would you let me know if this setup wheel fits the 2016 e63 wagon?
2)20x9.0 et32 5x112 Front
2)20x10.5 et42 5x112 Rear
Old Jun 16, 2022 | 11:43 AM
  #37
brfatal's Avatar
2014 E63S AMG
Rears will poke
Old Jun 16, 2022 | 12:50 PM
  #38
Avahdani's Avatar
e63 Wagon
is that mean it will rub or stick out?
Old Jun 16, 2022 | 12:53 PM
  #39
brfatal's Avatar
2014 E63S AMG
Stick out past the fender. Whether it will rub depends on suspension setup and tire sizing.
Old Jul 11, 2022 | 01:29 AM
  #40
Avahdani's Avatar
e63 Wagon
would anyone knows if this set up works for 2016 e63s wagon?
5x112
20X9 et+32
20X10.5 +42
tires:
235x35x
275 30
Thank,
Old Jul 15, 2022 | 06:52 PM
  #41
Avahdani's Avatar
e63 Wagon
Has anyone tried stock GTS wheels from 2017 on W212 E63?
Old Jul 15, 2022 | 06:57 PM
  #42
brfatal's Avatar
2014 E63S AMG
Won't even come close to fitting. My guy, you need to look at your stock wheels and take measurements to see how much outboard and inward clearance you have.
Old Oct 10, 2022 | 06:08 AM
  #43
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Little help please
I’ve always been on the lookout for something in my budget and that fits my style. Unfortunately I always have to ask first and keep missing nice wheels. Found another pair to ask about
how would these fit?
front 9.5 et 25 running 65 35s
rear 10.5 et 35 running 85 35s
what spacers would I need or is it a no go?
I have a 2013 63 wagon, stock suspension
thank you all so much
gary
Old Oct 17, 2022 | 10:01 PM
  #44
Baltistyle's Avatar
gary
bumpity bump.. any help appreciated. The wheels are rays gram light 57drs. Thanks
Old Oct 18, 2022 | 07:31 AM
  #45
mweber88's Avatar
2015 E63s S212
What were the specs of the stock wheels on your car?
If you don't know, you can find out here:
https://www.wheel-size.com/size/merc...lass-amg/2013/
Find your original specs, come back here, and we shall discuss.
Old Oct 18, 2022 | 09:54 PM
  #46
ThreeSix's Avatar
G550
Sounds like you're looking at some Supra spec wheels.
The fronts will fit with a 265, but you'll need to run a smaller tire in the rear in order avoid any rubbing. You could probably get away with a 265 on the rear.
Now as far as how it'll look...it probably won't look the greatest at stock height. Once you're lowered it'll be a different story
Old Oct 19, 2022 | 02:15 AM
  #47
AMGfifty5's Avatar
05 C55-gone 06 E55-gone 15 P85D 14 E63 S 11 Sonata 😅
I found a set of wheels that the owner says was for a e63 but the offset isn’t one I’ve seen anyone mention having before.
19x8.5
19x9.5
both front and rear have a 15 offset.
does anyone know how this would look?
Old Oct 19, 2022 | 07:11 AM
  #48
mweber88's Avatar
2015 E63s S212
19x8.5
19x9.5
If you're looking to put these on your '14 E63s listed in your signature, they will stick out 16mm more than the factory wheels did in the front, and a full 37mm (1.45 inches!) in the rear. I'm thinking that's rub territory, nevermind how it looks.
I wouldn't even consider it.
Old Oct 19, 2022 | 04:41 PM
  #49
Baltistyle's Avatar
Thank you for this info. You are exactly right in the wheels were from a Supra. Looks like if I’d like that brand I could do the 9,9.5 setup with some small spacers. Does the lower offset number by 12/15mm mean I need spacers, or that it would already be sticking out by that much more? Would you agree with needing it not needing spacer? I’ve never been a non stock wheels person so don’t want to mess anything up. I won’t be going lower than stock for the time being as I would not be able to get into my work parking lot, and there are tons of “anti wase” neighborhood speed bump island abound.
thanks for all the info.
Gary
Old Oct 19, 2022 | 10:48 PM
  #50
Rehabguy's Avatar
E63S
gary
Spacers do not = Universal fitment fixer upper. All spacers do is push your wheel OUT toward the fender.
19x8.5
19x9.5
Did they mean MB E63? lol! Talk about "buyer beware"!
Not to be racist or anything, but, y'all ever heard of the "term"... MEXIFLUSH?...
That's how it'd sorta look
