new engine
Old Oct 29, 2018 | 11:24 PM
Ahmad Abdo's Avatar
2011 e63 amg
new engine
Hello AMG fam
i have a 2011 e63 AMG with 73k miles on it
i recently got the car and I was driving on the interstate when I start hearing some rumbling from the engine area(failure sounds) but no leak no smoke nothing so I parked on the side and towed it to Benz dealer that they called me today and said there’s a damage in the bottom part of the engine, the crankshaft might be bad or bearings but they don’t what exactly the problem do they told me I’d have to get a new engine and i have no warranty nothing.
Anyone know about that or can advice me to do something about that?
Old Oct 30, 2018 | 12:55 AM
Stereolab42's Avatar
2019 GLC 63 SUV, 2013 SLK55
Originally Posted by Ahmad Abdo
Hello AMG fam
Yikes. Aren't new AMG engines from MB like $50k or something? You may have to find a used engine on eBay and have an indy install it. This is assuming your bottom end simply cannot be repaired. If I was in your shoes I'd get a second opinion on that (again from a respected indy).
Old Oct 30, 2018 | 01:41 AM
MaschioneCazzuto's Avatar
2016 E63 AMG-S, 2007 FERRARI 430, 2001 JEEP WRANGLER 60TH ANNI. EDITION SOLD 2011 E550 4matic
Old Oct 30, 2018 | 09:44 AM
PeterUbers's Avatar
FInd out if your engine had the notorious head bolt problem; you can google m156 benz headbolt problem; if so, ask Mbusa to have some mercy on you and give you some financial relief for this repair
you can find an m156 on ebay
Old Oct 30, 2018 | 10:27 AM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
I am thinkking the CAMs lobe issue.
Unless oil changes were far and few and incorrect type.
My W211 6.2 early 6.2 had no issues as the later 6.2 seem to be experiencing.
Knock on wood I don't think I would ever get back into a 6.2 knowing all these issues.
Old Oct 31, 2018 | 12:27 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
Hello AMG fam
My 2011 spun the #5 rod bearing at only 58k miles. The whole thing was chronicled with pics too in a thread something like "My 2011 totaled from an engine ticking sound?". Fortunately I had a reputable 3rd party extended warranty that covered it for only a $200 deductible to me. THEY PAID $19K !! This paid for a new crank shaft ($5k in the box alone), all new main bearings, all new rod bearings, and a new rod for #5 to be on the safe side. Dealer had the car for about 2 months. Ugh. If you scored the cylinder walls in the block, you are looking at even higher cost repairs. My block was still OK. If you are out of warranty, your best bet might indeed be to find a used engine replacement as others here have suggested.
Good Luck
Old Oct 31, 2018 | 09:59 PM
EMR2004's Avatar
2011 E63 AMG
What's your VIN number? Curious what production engine you have.... only the very early 2011s had the head bolt issue...
