Hello,
Have a 2016 E63S wagon.
Would like to remove the foldup cargo floor and bottom tray of spare tyre well to gain access for routing dash camera wiring.
Cannot figure out how to remove them. Do I need to remove the slide rails first?
Appreciate your help & instruction.
2dino
With you help I was able to pull them out. Thank you, EckFe1!
For future ref., foldable cargo floor section goes up away from the hinges.
Forward cargo floor flat panel is separate. Pull up front (towards front of car) edge to release 2 plastic clips then slided forward to remove.
Spare tyre well bottom tray - Found not necessary to remove to thread wire so I left it alone. Looks to be affixed by push pins but requires removing subwoofer first if complete removal is needed.
2dino
Reason: for clarity
