O2 Spacers
Old Feb 4, 2019 | 10:31 PM
c3004wife's Avatar
2008 c300
O2 Spacers
Anybody have any luck using these to prevent CEL on the M157 after removing the cats? I'd rather not touch the tune if I don't have to.
Old Feb 5, 2019 | 12:01 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
They don’t work for us. I tried 3 different styles and lengths. I could get the sensors to quit throwing O2 codes but then they’d throw codes for not getting warm enough.
Old Feb 5, 2019 | 09:05 AM
kponti's Avatar
E63
^^^That's the problem with these things is that you have to fine tune the diameter and length to be just right. Which is difficult to do especially with a wideband upstream.
Also knowing whether MB is using fractions of the upstream sensor or a preset parameter that the down stream runs would be helpful but also I was unable to nail that down on my old car.
Use Star to turn them off like we used to do in the old W211 platform. You will pass inspection with no lights. Renntech does that for you for a low low price of $900 -$1200 a pop 😉 so I know it can be done on this platform.
Old Feb 5, 2019 | 11:22 PM
b0kix's Avatar
just get a tune for $ 1000 and it will pass.
Old Feb 6, 2019 | 08:25 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Like he said.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Feb 6, 2019 | 11:26 AM
amgboy916's Avatar
2012 CLS 63
I swear every time I have a question about my car I stumble upon a thread where chiro has already answered it lol
Old Feb 6, 2019 | 11:55 AM
sunil517's Avatar
2014 E63s 1993 mazda rx7 on Boost
NYS Inspection and CEL
In NYS you will not get an inspection if you car has a CEL or No CEL but the monitors are not set.
So if you turn off your CEL via star and the monitors are not set you will not pass.
You are allowed to have 1 not ready.
I know this pain all too well from by 211 and will never delete my CATs if living in NYS.
I had luck with extenders on other cars but never BMW AMGs.
Old Feb 6, 2019 | 01:30 PM
Vrodman's Avatar
2015 E63s AMG, 2020 GLC 43 AMG
Same exact situation here in Cali. I just battled this when trying to sell my 2011. A couple of monitors refused to set and it was totally stock. Dealership ended up replacing the ECU under the 80k miles smog component warranty. But this cost me about 3 weeks of time to get it resolved and get the certificate while I had a buyer waiting and getting nervous about the car. All ended up fine though in the end.
Old Feb 6, 2019 | 01:45 PM
amgboy916's Avatar
2012 CLS 63
this happened to me on my 12 as well. monitors would not show ready. I was informed about the 80k mile warranty but my car was not even eligible for smog until I was at around 90 something k miles. its stupid. I advise people to check on this before they go over 80k miles.
Old Feb 6, 2019 | 06:38 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Sounds crazy but for my Sentra (not a C63) I just wrapped the O2 sensor in aluminum foil and tucked it away in the engine bay and never got a CEL.
