Need help -- torque for lower front strut bolts
Old Apr 26, 2019 | 01:57 PM
HPMan's Avatar
2014 E63 S
Hi,
I have received conflicting information regarding the torque spec for the two bolts at the bottom of each front strut that connect the strut to the hub/knuckle. I believe they are 14mm bolts with nuts. I have been told three different torque values, namely: 100Nm (approx. 74ft-lb), 120Nm (approx. 89ft-lb) and 156ft-lb. Does anybody know the correct torque spec? Last time I reinstalled the strut I torqued the bolts/nuts to 100Nm (with blue locktite) but I want to make sure that I haven't under-torqued them. This is for a 2014 E63S 4-Matic model. Thanks.
Old Apr 27, 2019 | 02:55 PM
V-AMG's Avatar
2016 E63s Wagon - CCB & CF package
Originally Posted by HPMan
Hi,
Call me ignorant, but I’ve never used a torque wrench on suspension parts. Just snug it up well and done. I literally just finished an entire front end on my buddies 996 Carrera, no torque wrench.
Old Apr 29, 2019 | 12:40 PM
lvevo's Avatar
Evo9
I think for bolts that are not holding something that is structurally important, then a "snug" tightening is fine. Bolts that are holding together something structurally is need to be torque to a certain value because they are not only holding parts together that are very heavy but are subjected to other forces such a vibrations and cornering.
@V-AMG for suspension parts I would use torque values because that is a structural component that is subjected to vibrations and cornering forces that is trying to pull it apart. Over torquing can cause a bolt to fail. Also looking up torque values shows which bolts are torque to yield or stretch bolts which are and should be tighten only once. So basically once you remove this bolt you have to buy a new one. A lot of sub-frame bolts are like this.
Old Apr 30, 2019 | 10:40 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
https://crafter.fastenal.com/static-..._Fasteners.pdf
Old Apr 30, 2019 | 11:30 AM
PeterUbers's Avatar
Isnt there some schematic like this for benz w212 amg 2014-16? Like this...
https://mbworld.org/forums/attachmen...le-bearing.pdf
Old Nov 16, 2022 | 11:46 PM
CZ 75's Avatar
E63 AMG
Pete, ever find the specs for our cars?
