Datalog | Ever wonder how efficient our water intercooler is?
In the meantime i thought it would be nice to show some datalogs of Intake Air temperaure aka IAT's on our cars. Which i havent seen anyone really show clearly anywhere on the forum.
I have the exact date written down somewhere, but as most of us know in 2013, AMG went to a full divorced intercooler plumbing.. Meaning nothing was shared with the engine water cooling as in previous versions of the M157 where it was the cooling circuits were shared.. The intercooler now had its own recovery tank, pump, heat exchanger etc. , separated.
As my car is a 2014, this is of course relevant to the newer system.
AMG claims that if the IAT rise above 113F, the electric coolant pump will turn on, and when the IAT's drop below 104F, the pump switches off. They claim their system keeps IAT's below 158F always.
These claims are not for the newer system as mentioned above but were written for the earlier model M157. Wether or not these targets have changed, i have not checked yet at this time.
On top of that, a few tuners also are altering these targets, and turning the pump on sooner.
its just some information to have to start with.
Anyways, on to the good stuff.
I have attached 3 pictures below..
This log was of me in local NYC roads on a 70F day, and then doing a Full throttle 3rd gear datalog, from around 2500K RPM to redline... So a full 3rd gear run, loading up the engine and turbos from low rpm, thru the entire rev range.
First picture is showing where the IAT's where before the full throttle run:
102F
Here are the temps peak right after i let off the throttle at the end of the run:
136F
And here is me coming to a slow complete stop just seconds after the run:
109F
Pretty impressed with the results! Our intercooler water system recovery speed is very impressive! Even more so that this is on a car that is running 5 PSI more boost then a normal M157 from the factory they designed this for.
IAT's started off at 102, rose to 136 at the end of the run, but came back down VERY quickly almost back to the starting point, down to 109. That is with me coming to a stop aswell, not cruising after the run.
That's a 34F rise in an entire gear, so the suppression of IAT isnt the best, but its in the normal range of good i think, esp for on a tuned engine.
So Great IAT recovery, good suppression, and not very fond of the oem targets AMG set for the IAT hanging around 100F+ all the time.
Hope you guys enjoyed, and i will be getting more datalogs of my car and a few members cars out soon here on the forum.
102F
136F
109F
IAT's started off at 102, rose to 136 at the end of the run, but came back down VERY quickly almost back to the starting point, down to 109. That is with me coming to a stop aswell.
Hope you guys enjoyed, and i will be getting more datalogs of my car and a few members cars out soon here on the forum and virtual ones aswell, so everyone can check and play with them on a hosted website
