2016 W212 E63s Limp mode with code P061A
iagnostic trouble code(DTC)detected P061A,try to find the tuner,but he dont wanna help,went to dealer,they scan it saying it maybe the throttle vale and they update the software for me for the throttle vale and tested no problem and pick up the car from them,but the next day i went to PA for car meeting it happen again on just S mode with around 3k-4k RMP,just wanna cry,i just want the car has pop and bang don't really care the speed,so any one could help me out for this case.
The best way to determine if you have a timing advancement issue is to disconnect your ECU for 20 minutes entirely. You can do this in about 2 minutes without hand tools. You don't even need to disconnect your battery.
If you reconnect it and your problem goes away for a few days or a couple of weeks you will likely have the issue I am describing. If it is this though, it will return eventually. If this is it and you can't get the tuner to fix it, you will likely need to get a tune from someone else to correct it. I'm surprised the dealer did not find your tune on the car. You were a bit lucky. Of course you know if you tell them about your tune, you will likely lose your warranty.
Good Luck
Call the guys at Eurocharged and start over before you destroy your motor.
You buy a car for $30-60k, that was originally $110-120k, and at the edge of what AMG delivered at the time.
You then save $1000 to have a tune done by an unknown guy that then is NOT standing behind his work and now you are wondering why **** is breaking?
That makes no sense.
Ask your dealer friend to flash back to stock, make sure car drives OK and then ask Santa for a reputable tune.....
